| Construction Tips Construction techniques and tips |
#11 |
Oh sweet. Thanks Ian.
#12 | |
The one I have is 25mm and gives plenty of room for the connector to go through the hole. A punch also doesnt leave any sharp edges.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#13 |
Hi Nigel.
Is there any trial downloads of PCBCAD40. Regards ian |
#14 |
Sorry I dont have a demo version.
The software does what it says in the ad.
#15 |
#16 |
There are tapered drills and stepped tapered drills, that can cut a variety of non standard diameters.
I burnt out one of my drills by turning down the speed too far, to suit cutting the big holes I was putting into my cast iron brake drums to increase cooling air and help prevent brake fade. Odd that one endeavour to cool led to another of overheating. That's when I went out and bought a proper drill with two proper speeds: 1100rpm and 400rpm.
regards Andrew T. Last edited by AndrewT; 9th January 2012 at 01:56 PM. |
#17 |
Yes a punch leaves a blunt hole and needs no more finishing.
#18 |
| Cutting holes in aluminium enclosures | emperor | Parts | 4 | 22nd July 2007 07:45 AM |
| making rectangular holes in aluminium case | AdamZuf | Everything Else | 7 | 23rd November 2006 03:39 PM |
| Cutting Nice Holes | jwatts | Multi-Way | 10 | 9th February 2005 12:46 PM |
| Best method for cutting driver holes? | dc | Multi-Way | 16 | 29th May 2002 12:27 PM |
| Page generated in 0.09410 seconds (74.78% PHP - 25.22% MySQL) with 11 queries |
