Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 12th January 2012, 06:17 PM   #11
"Much simpler, so I am just running one side of the AC (-) thru this"
Correct ... it inserts in the neutral line
You need to keep an eye on the bridge as it could get very hot and may require a sink
When I added the cost of putting one together with a premium outlet and IEC plus a heavy aluminium case ... I just bought 2 PS Audio Humbuster III at $150 each instead
Some of the valuve's of the caps I've seen are 2200uF and 3300uF at 16v
4700uF at 35v and if you look at the attached you'll see Bryston uses the circuit in some of their amps with 33000uF 6V caps
Sorry I can’t make a recommendation .. it was my own indecisions that led me to take the safe route and buy the HBIII’s
Old 18th January 2012, 04:17 PM   #12
Thanks for all your help, I think this may be a little beyond my abilities and if to do it right is going to cost $100, I might be better off just purchasing a PS Audio Humbuster III. Again appreciate you sharing your experience with this problem.
Old 24th March 2012, 04:22 PM   #13
can you post the ps audio humbuster schematic
Old 24th March 2012, 04:35 PM   #14
Much, an enormous amount of very much, has be posted about the way these AC Mains supplies can have a net DC component in the distorted AC waveform.
Similar amounts of explanation have been given on why some transformers are susceptible to this form of waveform distortion and why the DC blocker can come to the aid of these susceptible transformers.
And yet I still see all the crap being repeated on what the DC blocker is NOT capable of doing.
The capacitors are the working element in the DC blocker.
To remove DC you need some ...... capacitors,
The diodes are an overload bypass.
regards Andrew T.
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 26 5th July 2011 10:22 AM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 07:52 PM
?? DIY PS Audio Humbuster lgreen Solid State 38 22nd April 2011 12:29 PM
Question about DIY 'Humbuster' schematic Glowbug Power Supplies 8 14th March 2006 03:57 AM
Help with Schematic. CryingDragon Solid State 4 23rd October 2002 04:00 PM
Page generated in 0.07766 seconds (71.76% PHP - 28.24% MySQL) with 11 queries
