Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 6th January 2012, 08:08 PM   #11
tvrgeek is offline tvrgeek  United States
The paper I read on mu-metal suggested any strain on it would disrupt the carbon crystalline structure making it no better than plain steel. Just a paper, no direct experience. Besides, I can't find anyone who sells it in less than ton lots, so maybe that is a hint.
Old 6th January 2012, 08:26 PM   #12
Try a search on mumetal and mushield. I've bought small quantities in the past with no problem. It's not cheap. If you find a junk oscilloscope, the CRT shields are usually some form of mumetal. I know I posted the aluminum trick quite a few years ago, but everybody knows aluminum and copper can't shield magnetic fields! Fun- drop a strong neo magnet down a piece of copper water pipe.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 6th January 2012, 09:40 PM   #13
jackinnj's Avatar
Here it is:
Magnetic shields for transformers
Old 7th January 2012, 02:02 PM   #14
Mu metal is not particularly suitable for shielding power transformers as apart from the difficulty of working it without subsequent heat treatment it tends to saturate and then is ineffective. It is very good for shielding low level fields which is why it is used for signal transformers and tape head enclosures. Stalloy or similar alloys are deigned for the higher flux levels found around power transformers and are also easier to work.
Old 7th January 2012, 02:58 PM   #15
DF96 is offline DF96  England
They can't shield static magnetic fields. They can shield varying ones if they are thick enough, or arranged in a loop, via eddy currents.
Old 7th January 2012, 08:07 PM   #16
Stalloy. Not heard that term. Will WIKI. Thanks.
Old 7th January 2012, 11:40 PM   #17
The thickness of standard 1-ounce/foot_square copper foil,
at 35 microns or 1.4 mils, provides 1/E 1/2.178 attenuation
at about 5MHz, with progressively better attenuation for
higher frequencies per theory. Each 1/E is a neper, or 8.9dB,
thus 500MHz, 100x faster, would have 10 skin depths in that
same 1.4mil copper. Using a copper PLANE, to allow circulating
currents, provides 10 * 8.9 or 89dB for the high-speed-edge
energy of microprocessor clocks.
A 5MHz MPU clock would only be down 8.9dB, but assuming
1nanosec edges, the transient energy experiences wonderful
attenuation. This should permit integrating sensitive analog
circuits near modern MPUs, IF A PLANE (Vdd or GND or just SHIELD)
is between analog and MPU.
Old 8th January 2012, 10:47 AM   #18
marce is offline marce  United Kingdom
Old 8th January 2012, 12:18 PM   #19
thaumaturge's Avatar
McMaster-Carr
Nickel Iron Magnetic sheilding foil.
Doc
Ne timeas a facie mulierum ea ignorare
Resistors, metal film or metal oxide? gil1 Solid State 2 14th November 2010 02:16 PM
Metal dome should always go with metal cone? Is this a rule? Jay_WJ Multi-Way 5 5th February 2007 06:53 PM
ASC metal can polypro caps: ground the metal can to AC ground? jarthel Tubes / Valves 10 6th September 2006 12:54 PM
Metal Oxide vs flamme proof vs metal film ostie01 Parts 28 26th June 2006 06:38 AM
amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? siu sin man tho Digital Source 0 17th March 2004 12:31 PM
Page generated in 0.09431 seconds (78.02% PHP - 21.98% MySQL) with 10 queries
