Construction Tips Construction techniques and tips
Simple first-build to power two 600w 4ohm Subwoofer
Old 11th December 2011, 02:57 AM   #1
TrevorCook is offline TrevorCook
Default Simple first-build to power two 600w 4ohm Subwoofer
Price, ease of build and power trump sound quality (in that order). Looking to power just the subs for under $100. Any suggestions, places to get parts, first time guides are welcome!
Old 14th December 2011, 03:51 PM   #2
Alfonz is offline Alfonz  Bulgaria
Under $100?!
Do you mean power amp or building 2x SW?
Old 14th December 2011, 04:12 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
There is no such thing as a simple 600W 4Ohm amp suitable for a first time builder.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 14th December 2011, 04:26 PM   #4
If it makes a difference, quality really isn't an issue and 20-100hz is all I need. If not, where do you suggest I start?
Old 14th December 2011, 04:45 PM   #5
pinkmouse's Avatar
Your budget.
Seriously, caseworks and heatsinks alone will cost more than your cost limits. Add in a huge transformer, PSU caps, and then the components and PCB and you'll be looking at $250 minimum.
Then double this, as you're likely to blow it up a few times during construction if you've never worked with anything that high powered, the risk to yourself with the high voltage rails required, and then add another $250, (minimum) for the test equipment you realise that you need to get it working.
So, what can you do?
Buy a used PA amp - can be cheaper than you'd think.
Get some tried and tested Class D modules that you can just screw together and case up. Will cost more, but will give you the satisfaction of doing it yourself.
Start off building a 30W chip amp, then progress onto something using discreet components like a Symasym. Once that's up and running well, build a bigger amp, something like the new diyAudio class AB amp, at 150W you're getting there. Then start thinking about 600W...
Old 14th December 2011, 11:47 PM   #6
pski is offline pski  United States
+1 from this thread
To start, you need more money. Check out the plate amps at Madisound.
Simple first-build to power two 600w 4ohm SubwooferHide this!Advertise here!
Easy-to-build 600W Power Amp OliverD Solid State 45 28th October 2015 03:39 PM
Help with 4th Order bandpass enclosure for a 15" 600W dual voice coil subwoofer (PA) col Subwoofers 30 9th December 2011 04:04 AM
Exile Audio XPE12 12" Subwoofer 600W RMS newonty Subwoofers 13 4th April 2010 03:55 PM
running subwoofer at 2ohm or 4ohm justinc Subwoofers 6 1st March 2005 11:25 PM
Build Poweramp 4ohm high power da_madaxeman Solid State 15 23rd November 2003 09:51 PM
Copyright ©1999-2017 diyAudio
