Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 21st November 2011, 11:48 AM   #1
jeepy is offline jeepy  Switzerland
Default Wood cabinet for amplifiers?
Hello,
I am just wondering if some people noticed a difference in the sound (could be imaging or any other factors) when using wood chassis or cabinet rather than metal for a power amplifier.
Thanks,
Jeepy
Old 21st November 2011, 12:26 PM   #2
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
I have experienced microphonic effects with audio electronics.
I would say that generally source equipment, and pre-amps are more effected by microphony than power amplifiers.
Changing the construction or material to make the cabinet will change the dampening & resonance of frequencies so might tailor the sound.
Best improvements I have acheived have been by positioning the equimpment on a non resonant support that is solidly mounted to stop any accoustic vibration (such as a shelf mounted on a solid supporting wall).
Improvements subjectively involve better stereo focus, timing, and detail.
Old 21st November 2011, 12:58 PM   #3
Possibly with tubes at high volume levels, not with solid state.
Old 21st November 2011, 02:09 PM   #4
Speedskater's Avatar
In this day and age, I would think that the differences in sound are caused by interference.
Kevin
Old 21st November 2011, 03:22 PM   #5
lduarte1973's Avatar
isnt metal better for heat dissipation ?
Old 4th December 2011, 03:43 PM   #6
roline is offline roline  United States
roline's Avatar
Just put slots around the tubes for ventilation....
SO many tubes, SO little time!!!
Old 5th December 2011, 09:42 PM   #7
tvrgeek is offline tvrgeek  United States
Wood looks better, but it does not serve the required functions for shielding. Wood can be used if it is augmented with shielding. Look at the Grado head amp for example.
Solid state is absolutely sensitive to micro-phonics, just as tubes are. I assume you have heard of the piezo-electric effect. There is a camp that believes DAC's are fairly sensitive. The same techniques work: board isolation, potting, mass. Maybe not as bad as tubes, and of course, it varies with tube design.
My personal bias (sorry about that) is to mechanically isolate the transformers, as I can measure the effect on my 6ay7's from their vibration. I use wood for decoration.
seal wood inside cabinet pizzachef Full Range 23 2nd September 2011 12:10 AM
Wood chassis for amplifiers for sale! kringelis Vendor's Bazaar 2 21st April 2010 05:09 PM
Hi-end piano real wood cabinet weimanken Swap Meet 2 11th September 2009 10:20 AM
lightweight wood for cabinet? NED 209 Multi-Way 8 13th April 2008 06:57 AM
Pine wood cabinet palesha Multi-Way 3 11th February 2002 07:06 PM
Page generated in 0.09684 seconds (76.96% PHP - 23.04% MySQL) with 11 queries
