| Construction Tips Construction techniques and tips |
Does any Know how to design simple Stereo Audio Amplifier(Pre-Amp+Tone Control+Output Stage) by using LM358 op-amp and (8 ohm Speaker) ,the circuit should be working with 4.5V (e.g. 3 AA batteries)...????
I designed several circuits but I got 2 much noise ![]() I really need some help PLZ....one of the circuit that I built is show below(Op-Amp Audio Amplifier)... |
#2 |
Two problems: too much voltage gain (x300), and a noisy signal reference due to thermal noise from the 1M resistors. Assuming a 20kHz bandwidth I calculate 5.4mV of noise at the output, which is likely to be audible.
Another possible issue is instability. RF oscillation sometimes shows itself as excessive audio noise. |
#3 |
I'm experimenting this circuit but unfortunately,i'm still facing these problems....
any suggestion with some details to how reduce excessive audio noise....any help, I will appreciate it..http://www.diyaudio.com/forums/attac...er-circuit.jpg |
#4 |
I'm looking for simple volume meter schematic diagram using LED and transistors and 4.5 voltage source to implement it with audio amplifier circuit that shown above ????any suggestion.........
#5 |
The easiest level meter is to use an LED driver chip like the LM3915 or LM3916. There are probably others that were more optimized for consumer electronics, but they may be obsolete now that everything is digital. Take a look inside scrap cassette players.
#6 |
All resistors carry <a href="http://www.physics.ucdavis.edu/xdzhu/Physics122_2008/Johnson%20Noise%20Manual_2008.pdf">Johnson noise</a>. The higher the R value, the greater the noise. Your 1M resistors seem to be way high for normal outputs. You might also check the National Semiconductor <a href="http://www.national.com/ds/LM/LM158.pdf">datasheet</a> for your opamp for some ideas.
#7 |
I can not use any LED driver chip like LM3916 or LM3915....just transistors and LEDs
#8 | |
Could this be another case of non declaration of student/pupil status?
regards Andrew T. |
#9 |
Because for my experiment there are specifications for using some components,the list of the component that I can use to design the volume meter circuit : Transistors, Resistors,LEDs,Capacitors and AA batteries>4.5 volts.
So if any one can help me and provide schematic diagram I will appreciated.. ![]() Many thanks.... |
#10 |
| SIMPLE BUT EFICIENT AUDIO AMPLIFIER ! | Radu1984 | Solid State | 7 | 19th September 2011 07:14 AM |
| New Dynaco Design DIYTUBE Stereo 35 Power Amplifier | garyroach | Swap Meet | 1 | 23rd June 2011 01:06 AM |
| New Dynaco Design DIYTUBE Stereo 35 Tube Amplifier | garyroach | Swap Meet | 0 | 19th June 2011 05:16 PM |
| Looking to hire someone to help with simple headphone amplifier design | FasterHorses | Chip Amps | 4 | 17th May 2011 07:45 PM |
| TAS5706 simple full digital stereo amplifier | KOON3876 | Class D | 53 | 23rd September 2008 01:04 PM |
| Page generated in 0.10496 seconds (78.18% PHP - 21.82% MySQL) with 11 queries |
