Construction Tips Construction techniques and tips
Accepting ones limitations
Old 5th November 2011, 02:07 AM   #41
Conrad Hoffman is offline Conrad Hoffman  United States
Twist drills will work fine, just bring the hole up in a few steps and don't let it vibrate when you start drilling. Use a squirt of WD-40. It's the free-hand stuff where people don't clamp things that gets them into trouble.
I may be barking up the wrong tree, but at least I'm barking!
Old 14th November 2011, 09:05 PM   #42
CZ101 is offline CZ101  United States
Great thread!
I have a question: what is the consensus on drilling 90 degree holes in 16 gauge steel (1/16"), for example, without a drill press?
Would an electric hand drill used with a "drill guide" like so be up for the task?
I want to drill some tight clearance 6-32 mounting holes in a racked metal shelf.
Old 7th March 2013, 11:26 PM   #43
Lavcat is offline Lavcat  United States
Lavcat's Avatar
I was googling around old threads looking for something else when I came upon this one. I now can give an update on what I wrote about above.
So far I have been very pleased with my little Proxxon drill press setup. I was able to drill two 5/16 inch holes in 1/2 inch hardened steel, 120 mm apart. No marking, no scribing, no centerpunching, no spotting, no pilot hole. Just drop the drill bit down and go. Yes, I did use cooling fluid.
I used a mechanical edge finder and dial gauge to center the work in the y dimension and the edge finder to locate an edge in the x dimension. Measuring with the dial gauge I moved to the location of the first hole. Then measuring again with the dial gauge I moved to the location of the second hole. Easy, and with very nice results.
Old 7th March 2013, 11:50 PM   #44
rif is offline rif  United States
Neither a cowbow nor dog owner
rif's Avatar
If i may take things a step back here...if you don't have the extensive tools, Space and/or someone to show you the tricks, you could see if there is a woodworking co-op You pay a monthly fee, and get access to a fully stocked shop as well as classes.
Accepting ones limitationsHide this!Advertise here!
Can you help understand limitations of ClassA/G ? Bigun Solid State 86 20th August 2009 04:23 PM
Branch limitations when using includes Circlotron Everything Else 2 2nd May 2008 07:49 PM
LM317 CCS - Any limitations? Archwn Power Supplies 8 16th December 2007 04:12 PM
Capacitor limitations?? kimschips Power Supplies 12 25th March 2005 10:29 PM
