| Construction Tips Construction techniques and tips |
I have a problem in that I am bypassing some coupling caps (16 of them) The leads are heat shrunk as I have found in another thread, cutting this away is a real mess. The good news is that these are box type caps with steel ( I presume) knobs from which the leads issue. I need to solder some polystyrene bypasses to the steel. I have a Radio Shack heatsink ( the clip kind) a 300 wat Weller Cards quad solder and flux. The bypasses are Rel Cap RTEs epoxy encapsulted polystyrene. Any hints on soldering this combo would be appreciated as steel is difficult to solder to and the polys are delicate. Thanks for the help.
Evil looms. Cowboy up. Kill it. Get Paid. |
#2 |
BTW I also have some Silver Epoxy. Would this be better than soldering? Regards
#3 |
Hi- some pictures of all this would help.
#4 |
Cleaning the leads with sandpaper or scraping (knife blade) shortly before soldering should help. How about checking with a magnet to see if those knobs are really steel? It may be useful to remove some excess solder with a solder sucker before adding the new wires; you'll be able to wrap them tighter and more securely.
#5 |
Thanks for the magnet tip ! Stupid me. The knobs are not steel they are solder, which I should have remembered from my Bozak crossover days. I think will still go with the conductive epoxy though, as I am still concerned about heat and polystyrene caps. thanks again
| Subwoofer enclosure in steel? | metalsculptor | Subwoofers | 16 | 14th October 2010 09:54 PM |
| Soldering tips for soldering station BEST PRICE, FREE SHIPPING, 15% discount | vtech9815 | Vendor's Bazaar | 0 | 27th January 2010 04:40 PM |
| Steel as a heatsink? | spooney | Car Audio | 11 | 28th December 2007 04:02 AM |
| steel buschorns | scottwilko | Full Range | 94 | 12th December 2007 05:06 AM |
| Steel cabinets? | bfg9k | Multi-Way | 1 | 5th January 2004 03:35 AM |
| Page generated in 0.10090 seconds (73.85% PHP - 26.15% MySQL) with 10 queries |
