Construction Tips Construction techniques and tips
Some thoughts on alternative cooling
Old 14th October 2011, 08:43 AM   #41
R.I.P.
post39.
The upright radiators are connected TBOE, good.
The laid back generators must be stood up to ensure the circulation gets started.
regards Andrew T.
Old 14th October 2011, 09:16 AM   #42
Alexontherocks is offline Alexontherocks  Italy
actually I thuought of that and it would help in leaving space for more modules. Given adequate power supply and heat disposal capacity one is limited on the depth of the radiators in terms of how many modules can be installed.
I just checked and keeping everything alu (so distilled water can be used) I would be facing these expenses:
120 euros rads
30 euros fittings and tubings
8 euros 2m of alu extrusion
not bad given I can build a case from metal at no expense (a friend has a workshop).
also check out this video: the design is actually hindering thermosyphon effect but nevertheless the results are there.
Solar Thermosiphon Effect in Action - YouTube
Old 14th October 2011, 09:21 AM   #43
R.I.P.
Investigate toxicity and in particular Legionnaires and steps to avoid that disease.
If that water is contaminated at any time in it's cycle and then infiltrates someone's lungs, you have a serious illness to contend with.
Also once water goes into equilibrium temperature differential within the loop will be irrelevant
I don't understand what you are posting.
regards Andrew T.
Old 14th October 2011, 09:29 AM   #44
In regards to the last sentence it was a mistake on my part due to lack of coffee. In forced circulation water does not have any kind of temperature differential. Once equilibrium is reached the loop disposes whatever heat is dumped in it.
Basically there are no "hot or cold spots" in an ordinary cooling system once the water reaches equilibrium. This is a common misbelief among enthusiasts. This is also why they add reservoirs thinking it will provide a cold spot for water to decrease in temperature.
Obviously the thermosyphon effect is different and temperature differential in the engine which drives it. Sorry for that.
For the toxicity problem clorine, silver and even engine coolant will avoid the problem in most cases.
Old 4th November 2011, 06:18 PM   #45
Leolo is offline Leolo  Canada
Leolo's Avatar
A pump == noise. I can hear the hum from my flat screen monitor, so there's no way I'm not going to hear a pump or fan in my amp.
Maybe possibly bring the water line outside of the room and have the pump and fans in another room. People with air bearing turntables have the compressor in another room. But then piping air is a lot less fraught then pumping water.
Further thought: is passive pumping possible? Hot water wants to rise above cold. Is it possible to use this fact to get water moving? I suspect that the viscosity of water would be to high.
Old 6th November 2011, 02:13 PM   #46
R.I.P.
Leo,
the last few posts are discussing the requirements for the thermo syphon effect.
regards Andrew T.
Old 15th November 2011, 06:58 AM   #47
borninthefifties is offline borninthefifties  United Kingdom
Originally Posted by AndrewT View Post
Leo,
Andrew, why do you have to so patronising.
Leo is making a valid point, and this is a forum after all!
Your persistant cutting comments and authorative tone will only deter members from posting!
Maybe there should be an "IQ" level as a prerequisite to the membership of the forum, so that members do not post below your level!
Old 15th November 2011, 10:55 AM   #48
R.I.P.
Do you want to volunteer to repeat the content of the last few posts to save Leo the time of reading them for himself?
regards Andrew T.
Old 15th November 2011, 04:52 PM   #49
Not an unexpected answer, patronising, cutting and authoritve as per normal.
If I knew what you were talking about 'Headmaster of the forum', I would gladly do as you ask!:confu sed::confu sed::confu sed:
Old 15th November 2011, 05:14 PM   #50
R.I.P.
Originally Posted by Leolo View Post
.............Further thought: is passive pumping possible? Hot water wants to rise above cold. Is it possible to use this fact to get water moving? I suspect that the viscosity of water would be to high.
Originally Posted by borninthefifties View Post
Not an unexpected answer................as per normal..............
read his last sentence and let's get back to the topic/s
regards Andrew T.
Some thoughts on alternative coolingHide this!Advertise here!
Cabinet cooling darien87 Everything Else 12 7th June 2007 11:50 PM
LM4780 and cooling john_lenfr Chip Amps 27 19th July 2005 11:01 AM
rectifier cooling... kasra Pass Labs 7 20th December 2003 01:02 PM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 04:40 AM
