Construction Tips Construction techniques and tips
only drum and/or bass output
Old 7th October 2011, 10:26 AM   #1
anshul is offline anshul
Default only drum and/or bass output
hello people,
I am totally new to this field so pardon me if you find the question silly.
what i have is a 3.5mm jack, connected to two wires carrying varying voltage of a music file.
what i want - a circuit as small/compact as possible which gives me "only bass" varying voltage of the same music file.
for this, correct me if I am wrong, i need a bass equalizer IC and amplifiers.
I need very accurate results and a compact structure that's why i am using an IC for this purpose. I want to know the size of device which i would end up with. Also, suggest if you have any better idea.
Thanks in advanced.
Old 7th October 2011, 10:33 AM   #2
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Hi anshul, it sounds to me like you want an active filter, or active crossover. If you do a search on either of those you should get some results.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 7th October 2011, 10:41 AM   #3
thank you for replying wintermute.
can you tell me the size of a crossover? I want it to be very compact.
Old 7th October 2011, 11:05 AM   #4
just another
wintermute's Avatar
That's a bit like asking "how long is a piece of string"
Do you want to build something yourself? Or buy something pre-built? If building yourself it should be possible to make something quite compact. If you only need the bass (ie you aren't spliting the signal into low and high) a single sallen key filter should do the trick and it will have a low component count.
Other things to consider is how sharp you need the cutoff (12db / octave per stage in a sallen key) the steeper you need the cutoff the bigger the circuit will be due to needing extra filter stages.
Tony.
Some of my photos
Old 7th October 2011, 01:14 PM   #5
12 db/ octave is pretty good.
Thanks for explaining. For what I have understood, i am attaching a file, please check whether I am on the right track or not.
Anshul
Old 7th October 2011, 11:37 PM   #6
Enzo is offline Enzo  United States
An electronic crossover can be just the little circuit, or it can refer to a complete piece of equipment. AS a circuit, a crossover normally would be a high pass filter and a low pass filter, built around the same crossover frequency.
In your case you want half of one - you want the low pass filter.
That tone control circuit you show is not probably the best way to do it, though it is passive. An op amp based circuit can be very compact and not to complicated.
only drum and/or bass outputHide this!Advertise here!
The Missing element in Chipamps> how to achieve tight kick drum bass with chipamp? rhythmdiy Chip Amps 37 25th November 2013 06:15 PM
would full range muddle up with drum and bass? PreSapian Full Range 49 12th April 2012 05:41 PM
how large does a Karlson need to be to get semblance of a bass drum? freddi Full Range 31 20th June 2010 02:36 AM
high output sub bass mart34 Subwoofers 1 13th July 2004 04:06 PM
Copyright ©1999-2017 diyAudio
