| Construction Tips Construction techniques and tips |
#11 |
haha.... but our 60/40 are kinda hazardous to environment X.x I understand it now, thx
#12 | |
Magneto the Gravity Man
If that can actually be supported by factual evidence ...... .
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#13 | |
hm... because lead itself was poisonous ?
#14 |
#15 |
wow !, i bet its not cheap, haha ! maybe when i'm doing a serious project i'm going to use that !
#16 |
For the bottom photo type.
Stock #4606K-ND at Digikey, $2.20 Stock #534-4606 at Mouser $1.31 |
#17 |
Guitar,
you need not solder the collector / case of a TO-3! This is the way I did it - and: this is perfect. Iso 008.jpg Best regards - Rudi_Ratlos |
#18 |
Invest in some clean free solder flux.
#19 |
No - I won't.
I rather invest in 100ml of ISOPROPANOL 70 and use my old tooth-brush - which is much cheaper! ![]() Best regards - Rudi_Ratlos |
#20 |
I don't think ISOPROPANOL 70 will fix those solder joints.
Twisted Pear Audio |
| transistor mounting technique ? Heatsink | guitar89 | Solid State | 4 | 17th September 2011 12:26 PM |
| Soldering iron tip problem, help! | audio_tony | Construction Tips | 22 | 15th January 2011 04:51 PM |
| Weller soldering iron problem | rtarbell | Parts | 2 | 23rd June 2007 04:48 AM |
| Nightmare soldering problem with some resuscitated cones | VvvvvV | Multi-Way | 1 | 5th August 2004 07:24 PM |
| P2P soldering technique | Serow | Solid State | 2 | 21st September 2002 08:39 PM |
