Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 12th September 2011, 11:03 AM   #1
lduarte1973's Avatar
Default what is the best way to avoid box coloration ?
Old 12th September 2011, 11:39 AM   #2
marce is offline marce  United Kingdom
No Box, sometimes refered to as OB
Old 12th September 2011, 12:01 PM   #3
simon dart's Avatar
"box coloration" is often used as a term that covers all sorts of things:
Vibration of the box panels from driver reaction forces and back wave pressure,
The internal resonances of the box being audible through the driver cone,
Modification of the driver response due to box diffraction,
...to name some of the major culprits all can be lumped as boxiness.
The inconvenient truth is that everything matters! There's lots to understand here including the fact that there is no simple answer. The ear/brain is very sensitive to different patterns of resonances too. Even OBs can sound quite coloured if you get bad edge diffraction.
All generalizations are false, including this one.
Old 12th September 2011, 12:16 PM   #4
kevinahcc20's Avatar
Eliminate the box (dipole)!
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 12th September 2011, 07:44 PM   #5
FullRangeMan's Avatar
A OpenBaffle or Dipole is a great way of get rid of box colorations and get more music flowing to front and rear sides.
A good suggestion are the usual Visaton B200 and the Eminence Alpha15A, the crossover is just a 4,7mH inductor at 290Hz.
Seems to me, there is some threads about this project on this Forum and abroad.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 12th September 2011, 07:47 PM   #6
SirByrd is offline SirByrd  United States
SirByrd's Avatar
Brace the cabinet until is behaves like a solid piece rather than a bunch of panels, then make sure you get internal damping "just right"
Old 12th September 2011, 08:09 PM   #7
frugal-phile(tm)
planet10's Avatar
One of the boxiest speakers i ever heard was an OB.
Here is one approach to making boxes with a low box signature
Discussion on what materials to build speakers out of
(a long read)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th September 2011, 12:01 PM   #8
Interesting...
One of the least boxy sounding speakers I have had have been the curvy changs.
I think maybe it may be useful to determine the irritating things boxes add to the sound.
My pet hate are some bass reflex designs, the chuffing out of the port I find very irritating.
Old 13th September 2011, 01:46 PM   #9
Don't build "monkey coffins". Angle sides, use braces and use multi-layer construction. Try not to create multiple resonances at similar frequencies. I've never heard one, but remember the sand filled walls of some speaker from the 1950s or 60s? Be careful of port sizes so you don't get port noises. Get damping just right!
I used to be an audiophool like you but then I took an arrow to the knee.
Old 13th September 2011, 08:25 PM   #10
ODougbo is offline ODougbo  United States
Angles, yes of course, small front/baffle board also; stands are important.
Pic ~ I made about 20 of these, using Peerless 1591, morel tweeter and a simple 6 db crossover. They sound great, bass is awesome. Not only are the sides angled the walls are lined with lead. If they look a bit old, you’re right, about 20+ years, still sound great!
The 5 ¼” Peerless woofer was ideal, wow what a lot of bass; too bad they discontinued them long time ago.
*Back then, we used to pull the dust covers and insert foam plug(s), “opens” them up quite a bit.
Has someone here REALLY been able to get rid of horn coloration ? angeloitacare Multi-Way 132 22nd September 2011 09:17 PM
Is this box building technique using scraps to avoid internal speaker resonance good? loninappleton Full Range 4 17th April 2011 07:22 PM
Tubes to avoid Sch3mat1c Tubes / Valves 105 25th October 2010 05:19 AM
Help me avoid a 5 way ?? Scott L Multi-Way 8 12th September 2010 05:45 PM
How to make a small, very effective, no coloration, phase inverter for signal? Destroyer OS. Digital Source 7 9th March 2008 07:31 AM
Page generated in 0.11211 seconds (78.25% PHP - 21.75% MySQL) with 11 queries
