Construction Tips Construction techniques and tips
Slectable momentary or latching action
Old 7th September 2011, 12:41 AM   #11
TheFixer is offline TheFixer  United States
I've kept at this and found I got it wrong above.
Momentary switch should be connected to the clock line, while the data line is connected to the "not Q" line.
Then, at a touch of the momentary, the flipflop will go from Q output, to Not Q.
Still... How can the flipflop keep the output high after the momentary witch is released? Doesn't there need to be another power connection directly to the flipflop somehow?
thanks
Old 7th September 2011, 01:16 AM   #12
Enzo is offline Enzo  United States
Any basic logic tutorial will cover flip flops, whether CMOS or TTL. The configurations will be the same, just the part numbers and voltages will differ.
All logic ICs need power and ground connections. SOme pins may be also conected directly to V+ or ground. And you may see pins connected to other pins, for example, the /Q conected back to the data pin. Now every time the clock advances, the Q and /Q will toggle, putting the opposite state on the data pin.
The whole point of flip flops is that they only change state when you clock them. Or when set and reset pins are enabled. And even then, rising edge and falling edge matter. They will latch into the state you put them
Old 7th September 2011, 01:51 AM   #13
Almost all of the tutorials and such that I encountered used a block diagram for the flipflop. the diagram would only show 4 lines, data, clock, Q, not Q.
They didn't show the V+ or gnd.
Duh, that's what I was missing. thanks.
Old 8th September 2011, 01:03 AM   #14
The power connections are usually assumed. SOme drawers will add them to one of the gates in the IC, but in logic, every chip has them, so they don;t clutter the drawing with them.
Slectable momentary or latching actionHide this!Advertise here!
Latching Switch Assemblies bishka Parts 9 19th September 2010 08:07 AM
control a latching relay with one switch? peace brainerd Parts 13 8th January 2009 05:24 AM
Driving a latching relay Nixie Parts 5 28th August 2008 08:41 AM
Momentary Switch mourip Parts 11 26th June 2006 10:53 PM
555 timer latching nickch Parts 1 20th July 2005 09:48 AM
