Construction Tips Construction techniques and tips
How to mount chassis feet?
Old 18th August 2011, 02:51 AM   #1
cersepn is offline cersepn  United States
Default How to mount chassis feet?
So i bought a chassis that came with supplied rubber feet (ugly but functional, i guess ). But i haven't the slightest clue how they are supposed to be mounted. Any ideas? The accessories package only has screws and no nuts. The bottom of the chassis has no pre-drilled holes for the feet.
I'm guessing it has something to do with the metal washer, but there are no nuts supplied, so how do i tighten up the screws? The screws are also too short...
Old 18th August 2011, 04:23 AM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
That style foot mounts using a pan head screw through a hole in the chassis, either tapped, or with a nut, washer and lockwasher on the other side. You need to make a trip to the hardware store. I suppose you could also use a disk of double stick foam tape if you don't want to drill a hole- some of them are very strong. I've no idea what that ugly black disk is- or is it the other side of the foot. Not exactly commercial quality stuff!
I may be barking up the wrong tree, but at least I'm barking!
How to mount chassis feet?Hide this!Advertise here!
Chassis mount connector strip albertli Tubes / Valves 3 12th January 2011 02:54 AM
DIY spring suspension feet for Chassis? jaimango Parts 15 28th October 2010 10:37 AM
Looking For Chassis Feet or Spikes dantwomey Chip Amps 2 21st May 2009 12:51 AM
chassis mount RCA jacks biff584 Parts 6 12th February 2005 06:23 AM
UK Source For Chassis Feet jonclancy Parts 0 23rd November 2003 05:37 PM
Copyright ©1999-2017 diyAudio
