Construction Tips Construction techniques and tips
Point-to-point wiring done right...
Old 12th August 2011, 07:06 PM   #1
VictoriaGuy is offline VictoriaGuy  Canada
Default Point-to-point wiring done right...
A lot of diy projects seem to be trying to imitate the 'Oriental style' of p2p ('all right angles, please, and many unsupported connections') or the Fender (guitar amp) style with components neatly lined up on a eyelet/turret board and long connecting wires to tubes and controls.
We really can learn a lot from looking at construction practices from the past, when p2p was the only method of building tube equipment. (I recently read a post where the writer decried the 'messy' wiring on a 50s radio- apparently not enough 90 degree angles in the wiring to suit...)
I picked up a console yesterday - nice little 'Chisholm' stereo SE EL84 power amp & PS with the usual remote tuner and phono preamp.
Though they did use the chassis as ground connection, the unit is surprisingly hum-free.
Have a look at the pics, and notice:
-spacious chassis
-power & AC at one end, signal and amp at the other
-no unsupported connections
-maximum use of the tube lug connection points
-inputs right at the preamp tube (7025/12AX&) - note the blue and red wires from inputs right to grids (no grid stoppers, but seems to work OK)
-lack of 'wire' used
-tight spacing on the 3 tubes so that resistor and cap leads can span the gap.
We can learn from those guys.....
Old 12th August 2011, 08:58 PM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
If you want to do it "right" I suggest looking at MILSPEC point-to-point wiring. Take a look at some Tektronix oscilloscope modules for example. That stuff's tight! The contraptions you show don't offer much serviceability and as you build them you'll find that it gets harder and harder to get the soldering iron in there without burning things up.
The key is to plan the circuit out on paper first. Take a look at my 6LU8 Spud for example. I'll let you guess which channel was planned on paper first...
~Tom
Old 12th August 2011, 09:34 PM   #3
nic6paul is offline nic6paul  United States
Also the tubes in the first post seem a bit close together. Doesn't Building Valve Amplifiers suggest 1.5x tube diameter for spacing?
- Nic
Old 12th August 2011, 10:37 PM   #4
Well, first you have to state which channel you think was wired 'better'.....
Old 12th August 2011, 10:40 PM   #5
You may be correct. Remember that in a console the tubes are 'in open air' (like most modern diy stuff), not inside a case (e.g. AudioNote, Heathkit!)
The fact that this console has been in regular use for 50 years, still with the original tubes as far as I can tell, should say something to that issue.
Old 12th August 2011, 11:03 PM   #6
I used to teach high school science, and in every class there were students who used to think that the circuits wouldn't work properly unless the connecting leads were bent to show 90-degree corners, as in the schematic.
a.k.a. - "I don't know why my amp squeals and hums; I used lots of wire and laced them all together in neat bundles just like in the 'milspec.' pictures".....
aka "What does it matter if I put 15" of wire between the input jack and the preamp tube on my guitar amp"....
It's amazing how stupid all those people were, building tube 'contraptions' for 40+ years...
Fortunately we can 'get away with 'bad wiring' for most audio projects, so it really doesn't matter.
Old 12th August 2011, 11:29 PM   #7
Enzo is offline Enzo  United States
A little nitpick: I don't consider the Fender eyelet board approach to be "point to point."
The whole idea of "point to point," is that components are wired between , well, points. The Fender uses a part board with wires running to other places. It may be hand-wired, but not point to point.
Old 13th August 2011, 01:12 AM   #8
I agree 100%. Same applies to turret board construction, IMO. Turrets individually placed, close to the tubes (Pete Millett's Mighty Midget is a good example) are true p2p - really like individual solder lugs placed where they are needed.
I'm no purist- I've used eyelet & turret for power supply sections, and PCB for regulators, etc. Just more 'tools' for the toolbox.
I just hate to see the 'rat's nest' of wiring or the connections in mid-air that are so common... and commonly admired.
Old 13th August 2011, 01:24 AM   #9
diyAudio Member RIP
Or not as the case may be. I cannot see much evidence of good wiring,
e.g. its good to run power supply leads in the corners of the chassis.
Good PtoP wiring layout is as important as PCB layouts, and one of its
advantages is it can be better, a lot better if the component layout
is determined by the wiring issues and not the other way round.
rgds, sreten.
Old 13th August 2011, 02:47 AM   #10
I don't understand.
Except for the heater wiring, there is NO power supply wiring anywhere near the working circuit. Plate resistors come straight off the filter cap, it seems.
Which wires should be running in the corners of the chassis in this example?
I'm eager to learn- do you have an example of better wiring for a circuit like this (2-channel SE)? I need something to study.
Thx.
Point-to-point wiring done right...Hide this!Advertise here!
Point to point wiring help chrish Tubes / Valves 26 17th August 2007 07:52 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
point to point wiring diy student Solid State 8 24th September 2001 01:56 AM
Copyright ©1999-2017 diyAudio
