Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 13th August 2011, 09:18 AM   #11
marce is online now marce  United Kingdom
Good PtoP wiring layout is as important as PCB layouts, and one of its
advantages is it can be better, a lot better if the component layout
is determined by the wiring issues and not the other way round.
I dont understand this either, when laying out a PCB the importance of connections and connectivity determine how you place the components, not the other way round!
Old 13th August 2011, 03:59 PM   #12
DF96 is offline DF96  England
Build it as though it is RF, with short direct connections, as the valves don't know they are only supposed to amplify audio. Alternatively, copy a published layout exactly. Don't use long wires like a guitar amp, or tidy wires like military stuff.
Old 13th August 2011, 05:00 PM   #13
Well, that makes two of us, at least!
I think that reading (parts of) 1950's ARRL Amateur radio Handbook when I was 12/13 years old 'messed me up' for modern wiring styles!
Old 15th August 2011, 08:47 PM   #14
badman is offline badman  United States
badman's Avatar
If one takes enough care, they can REALLY limit loop length by keeping resistors etc right at the socket.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 15th August 2011, 10:20 PM   #15
I find it tricky to do in practice, but I'm aiming toward that ideal. Using the center connection point of 9-pin (&7-pin) sockets is another thing that I tend to forget until the project is wired up. Then I see that connection point, and realize that I could have saved going to a terminal strip (and back to the tube).
Not so easy as it looks.....
Point to point wiring help chrish Tubes / Valves 26 17th August 2007 07:52 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
point to point wiring diy student Solid State 8 24th September 2001 01:56 AM
Copyright ©1999-2013 diyAudio
