Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th August 2011, 01:40 PM   #21
Speakerholic
Cal Weldon's Avatar
Andrew, I sympathize. Biscuit joiner and screws were my method of choice before I bit the bullet and got the nailer. I will never, repeat never regret the decision. Screws seem like torture now, especially when you get into the trickier stuff.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th August 2011, 01:53 PM   #22
I am making some smaller 2 ways at the moment with marine ply, I want the ply to be the final exterior finish so no screws. I am going to use just a few biscuits and rely on but joints and some cleats. Nothing fancy, just softwood braces that will help me to align everything on glue day. Will use PVA glue, stuff is impermeable once set in my experience.
Have always used screws in the past, millions of them. They add up so fast!
Old 4th August 2011, 02:01 PM   #23
Speakerholic
Cal Weldon's Avatar
Hi Mick,
I think you'll find biscuits and cleats do similar things so you can probably drop one or the other. I can't think of why you might need both.
Old 4th August 2011, 02:13 PM   #24
I suspect you are right Cal, thanks. In that case the cleats are preferable because they will be also add rigidity. On the other hand I have not spun up my biscuit joining thingy for a while so I might whip a few in for good measure
I used screwed cleats (again to help align things) and butt joint screws and glue in my last sub project. It is ultra tuff!
Old 4th August 2011, 02:28 PM   #25
There is wood glue available that expands and foams upn curing. This one will also fill small gaps and make the cabinet airtight - all at once.
Be aware that you will not be able to remove it from clothes, fingers, furniture ......
I can post a picture of a raw cabinet that used this type of glue if anyone likes.
Charles
Old 4th August 2011, 02:42 PM   #26
Charles
But it is not as strong as PVA! Been there done that.
Cal, are your boxes watertight? I haven't bought a nailer in a while, but I thought they cost less than a biscuit joiner and I am pretty sure nails cost less than biscuits.
PVA even cured will fail with weather exposure. It will take getting wet once or twice.
Glue blocks started with hide glue, you really need them and properly used you rub them to join the panels and no clamping is needed.
Modern glues set differently and clamping is good. The idea when using screws is that they act as clamps until the glue dries and then they really aren't needed. With a modern nail gun run at the proper air pressure the same clamping action happens!
One precaution about modern PVA glues is some have a filler added to allow it to be thicker and extend working time, really don't like that stuff.
The second is never let it freeze.
A semi-serious consideration with wood block reinforced butt joints is the wood used for blocks. When you rip the wood into strips it may warp on you. When buying the wood for the reinforcements look for long straight parallel grain. "Figured" wood is not a good idea. Yes, pines work well. I would avoid red oak, where maple is probably best. Heartwood is particularly good.
Old 4th August 2011, 02:53 PM   #27
Speakerholic
Cal Weldon's Avatar
I have posted some testing done on wood glues.
The lowdown on wood glues
Old 4th August 2011, 03:18 PM   #28
Speakerholic
Cal Weldon's Avatar
You bet, I use them for river rafting during the summer months.
Mine is air so there aren't cheaper but 5000 nails are pretty cheap. Mind you nailers are fun to use so I probably put about 5 times the nails I need.
Yup.
Unless you attach them to one panel ahead of time. I do that so there are no alignment problems with butt joints. Everything just falls into place. Adding them after defeats that.
Right but I can't remember actually going back and removing them can you?
Well now let's not forget that even plywood warps a little and the clamps are there to bring the pieces up snug during nailing. 1 1/4" nails aren't so good at that.
I use the thicker stuff a.k.a. yellow glue but because it sets up faster not slower.
I've made that mistake.
Oh ya, looks like curly fries sometimes.
Is figured wood what we call dimensional lumber ie 2X4? If so I agree. Doesn't stop me from using Spruce though. The Pine in these parts is far too knotty.
Old 4th August 2011, 04:22 PM   #29
jimbro is offline jimbro  United States
Or - you could use 2 different materials to make the panels, like particle board and ply. Make the inner panel smaller so they form rabbets. It'd take some planning and care laminating but assembly would be fast and you'd get acoustic benefits. Or so I've read. I've made bookcases like this but never speakers. Don't think I'd attempt it on those octagons.
Old 4th August 2011, 04:29 PM   #30
Cal,
Attached is what I mean by "Figured" wood. And if you raise your own pine it would probably be better behaved.
The family Pinaceae covers both commercial spruce and pine forgive me for being so imprecise.
Undoing wood glue...advice needed :( Glowbug Full Range 10 23rd December 2007 03:11 PM
Finger joints vs. screw and glue PRNDL Tubes / Valves 35 21st November 2006 12:24 AM
for a wood chassis, is glue enough? riotubes Parts 3 6th October 2006 04:25 PM
FE127E hole size, Butt joints and using PVA glue with MDF bluegti Full Range 32 19th June 2006 12:53 PM
Best way to glue wood without clamps? mr_push_pull Multi-Way 40 11th October 2004 06:21 AM
Copyright ©1999-2013 diyAudio
