Butt joints,wood glue strong enough? Butt joints,wood glue strong enough? - Page 10 - diyAudio
Construction Tips Construction techniques and tips
Old 25th August 2011, 03:08 AM   #91
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by pski View Post
No special clamps. Only bar clamps are needed if you have enough to do the full square at one time.. and a flat surface
Of course, "picture frame clamps" x 2 work very well. The issue there is whether they are big enough x and y.
P
Doing a box with bar clamps takes a couple of people, for me anyway, and the slip factor just isn't worth taking the chance. Mitre clamps on the other hand remove the guess work and the heartache of something possibly going wrong. You can make them yourself if you have a few extra minutes and a little skill under your belt. I don't bother when the tape method works so well.
planet10 needs your help:
Let's help Ruth and Dave
Old 25th August 2011, 03:09 AM   #92
Speakerholic
Cal Weldon's Avatar
Originally Posted by bunkie View Post
These days my biscuit joiner is mostly gathering dust.
Mine too.
Butt joints,wood glue strong enough?Hide this!Advertise here!
Best way to glue wood without clamps? mr_push_pull Multi-Way 44 26th March 2015 12:44 AM
Undoing wood glue...advice needed :( Glowbug Full Range 10 23rd December 2007 03:11 PM
Finger joints vs. screw and glue PRNDL Tubes / Valves 35 21st November 2006 12:24 AM
for a wood chassis, is glue enough? riotubes Parts 3 6th October 2006 04:25 PM
FE127E hole size, Butt joints and using PVA glue with MDF bluegti Full Range 32 19th June 2006 12:53 PM
Copyright ©1999-2017 diyAudio
