| Construction Tips Construction techniques and tips |
Hello,
I am a first time builder - gonna build a pair of enclosures, full driver design. Could anybody give some advice on how to secure the driver to the wood enclosure? I assume that one would use screws but should a bead of silicone sealer also be used between the driver and wood or should i make a gasket out of rubber and use that instead? Also, what type of wire is used between the driver itself and the terminals? I assume that some type of shielded cable would be needed. Thanks, Steve |
#2 |
Check out the Enclosures section of Zaph audio's design mantras.
Zaph|Audio I'm no expert but here are some basic guidelines: You HAVE to countersink a fullrange driver(and all midranges and tweeters). Regular screws should be good enough. For a driver under 7" it's advisable to chamfer the inside edge of the opening for better airflow from the back. You should predrill the screw holes with a small drill because the wood might crack when you try to put a screw through it. I've seen advise about pouring some wood glue in the screw holes for better support but I've never done it. Any method that decouples the driver from the enclosure will reduce vibrations and result in better sound but there's no practical way to achieve a full separation. A rubber seal will help but won't eliminate the problem because the driver will still be coupled to the enclosure through the screws. The better approach is to stabilize the box itself by means of cross-bracing(not necessary for drivers <5") and spike feet. |
#3 |
Thanks Boris.
Sorry if my questions are dumb. What i still don't understand is what you mean by countersinking the driver. The driver already comes with pre-drilled holes for mounting along with screws. I am using MA Alpair 7 G3 - 4" drivers. Are you saying that a have to countersink the driver's mounting holes? or countersink the holes in the cabinet? If you are talking about countersinking the holes in the cabinet then i don't understand what purpose that serves. Regards, Steve |
#4 |
I usually use wood screws with a black finish. Wood screws will hold the driver just fine. It is important to countersink the driver so it is flush with the cabinet. A router circle jig is the easiest way I have found to do this.
A lot of speakers come with a gasket, usually made of foam. Sillicone or rubber should be fine, but sometimes I skip a gasket completely. Regular stranded wire is fine, sheilding won't do much here, that's more for signal level connections. Just use copper wire of a decent gauge. -Nelson |
#5 |
Ah, now i understand.
Thanks guys for the information!!! I am quite excited about this project! |
#6 | |
frugal-phile(tm)
All MA driver scan with a set of Allen headed/hex screws. You'll need a metric wrench.
For wire we use single strands from solid core CAT5 (2 or 3 starnds -- extra strand on the ground if you use 3). People that have switched from more conventional wire to the skinny stuff have almost with out exception noted improvement. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Dave,
Referring to CAT5 - are you referring to CAT 5 Coax cable? |
#8 | |
Category 5 cable - Wikipedia, the free encyclopedia Jeff |
#9 |
Note that the outer bezel on latest version of the Alpair 7 come in 2 pieces. Unless you really want to see the embossed logos on the outer ring (they are very pretty), I'd plan on using them without. They add 1.5mm to depth and 5mm to outside diameter.
Allow approx 1mm larger diameter hole if rebating the drivers (makes them much easier to remove if needed), and be sure to very carefully handle the drivers, and cover them when installing the mounting screws.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 22nd July 2011 at 09:29 PM. |
#10 |
Guys,
Thank you very much for your responses - very useful information. I will post pictures when i'm done with the project. Regards, Steve |
| Using toroid mounting bolt to secure PSU board? | mymindinside | Construction Tips | 2 | 19th March 2010 03:00 AM |
| Epoxy / Caulk to secure large components to PCB | Everlast | Parts | 7 | 22nd July 2009 11:28 AM |
| How to secure/fix fragile wires to veroboard? | HankMcSpank | Everything Else | 10 | 8th July 2008 07:48 PM |
| Have enclosure, need driver | diydave | Subwoofers | 0 | 11th April 2008 02:49 AM |
| How do you secure your cables inside your cabs? | dublin78 | Multi-Way | 15 | 13th March 2008 09:26 PM |
| Page generated in 0.12781 seconds (80.97% PHP - 19.03% MySQL) with 10 queries |
