Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 15th July 2011, 09:59 PM   #1
qguy is offline qguy  Canada
Send a message via AIM to qguy Send a message via MSN to qguy Send a message via Yahoo to qguy
Default Rounded edges with 3/4 MDF
On rounded edges, what do I need to do to to achieved something like this ?
Do I need to double up on the top panel to prevent any weakness as the rounded edge would become very thin ?
if no additional top layer is needed, do I need to reinforce the corner from the inside ?
na
Old 15th July 2011, 11:07 PM   #2
Did it Himself
richie00boy's Avatar
I have thought about this too. My idea was to add square reinforcement to the edge inside the box.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 15th July 2011, 11:14 PM   #3
As long as the radius of the curve is not larger than the thickness of the mdf you should be fine.
Old 16th July 2011, 12:19 AM   #4
SirByrd is offline SirByrd  United States
SirByrd's Avatar
You can also purchase MDF corners up to 6" radius.
CABINET CORNERS
Old 22nd July 2011, 10:45 PM   #5
pski is offline pski  United States
+1
Those look like 1/2" round-offs so you should have no issues: none of the "joint" will be changed.
P
Old 22nd July 2011, 11:39 PM   #6
gychang is offline gychang  United States
how about using a router with a round bit?
Good sound from Phoenix, AZ
Old 22nd July 2011, 11:54 PM   #7
I just did that and I really can't tell you how beautifully MDF routes. I couldn't believe that cutting the full 1/2" round-off would be effortless and only take one pass.
You will test the depth setting on scrap until you see it's "really" round. To do that, you start setting the "tiny" point on the outside of the bit so it's just a little above <too deep> above the "table" of the router. When you make a test cut, it will have a little "shelf" on the side of the cut that points up through the router.
The quickest way to get an excellent depth setting is to use a small (6") ruler. Set your test depth and then drag the ruler across the bottom of the router from the outside to the center and see if it "hitches" on the outside of the router bit. I look at this with a lighted magnifier and you really can see how far up/down you need to change the depth.
How else would you do this?
P
Old 23rd July 2011, 12:00 AM   #8
This is how I round the front panel. You can do the same thing with the top and bottom of the box. The router bit to use is Round Over Edge Forming Bit.
AmpsLab.com
Old 23rd July 2011, 02:06 AM   #9
Or just use 1/4 round.
Old 23rd July 2011, 02:16 AM   #10
jcx is offline jcx  United States
why doe the pic show the wrong edges rounded?
How to treat MDF edges? chatziva Construction Tips 10 17th January 2010 04:21 PM
Full roundover vs. rounded w/ corner edges Pallas GedLee 1 22nd October 2009 02:05 PM
MDF edges and screws rinx Multi-Way 32 16th August 2008 03:36 PM
Veneering rounded edges tktran303 Multi-Way 1 27th June 2007 01:54 PM
how to make rounded wooden edges? legendaryfrog Multi-Way 4 21st November 2006 03:12 PM
Page generated in 0.09416 seconds (79.68% PHP - 20.32% MySQL) with 10 queries
