Construction Tips Construction techniques and tips
MDF, GLUE and nails
MDF, GLUE and nails
Old 12th September 2011, 01:41 PM   #21
ODougbo is offline ODougbo  United States
Yes clamps are the ticket to a good project. Bar clamps are by far the cheapest around, I bought a new pair at woodworking show recently for $5 bucks (you do have to supply/find pipe).
The Jorgensen Clamps are certainly top notch, cabinet shop grade, but the cost went way up on them. They make look-a-like clamps, but they bend and don’t last long.
I haven’t seen any one mention the Gorilla Glue (polyurethane glue), it’s a little messy, but the glue will fill any gaps you may have. Don’t forget to wet the edge of the wood with water before using! Oh boy, it is strong!!
There’s another trick I use for the inside of cabinets, especially if you’re not sure the box is sealed - pick up a can of undercoating at an auto store (it doesn’t cost much). It takes a while to dry, set the box in the sun for a while if you can; let it harden up before final assembly. The product is also good for dampening, to a small degree.
Old 12th September 2011, 01:47 PM   #22
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
MDF, GLUE and nails
Fact: You can never have too many cramps/clamps. You can always find use for a couple more on any glue up.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 12th September 2011, 02:03 PM   #23
Loren42 is offline Loren42  United States
The issue I have with those products is that they outgas VOCs and they may attack the glues used in the driver over time.
I usually apply a small 1/4 round or square stock on the inside corners with copious amounts of glue to strengthen the corners and insure air tight bonds.
Old 12th September 2011, 07:09 PM   #24
amc is offline amc  Canada
Originally Posted by Cal Weldon View Post
Get a circular saw and a straight edge or sawboard you can clamp in place for cutting. Nice cuts, relatively inexpensive and easier than a table saw which can be somewhat tricky if your experience is limited, not to mention expensive.
Cheers
I made a "door board" after seeing this video when trying to figure out how to cut a straight edge with my circular saw. Works like a charm, highly recommended.
MAKING STRAIGHT CUTS WITH A HOMEMADE JIG - YouTube
Old 12th September 2011, 10:39 PM   #25
ByronInPortland is offline ByronInPortland  United States
ByronInPortland's Avatar
It looks easier to use than the aluminum guide I bought. I think I'm going to build one. Thanks, AMC!
Old 12th September 2011, 11:27 PM   #26
lrntglls is offline lrntglls  Canada
the way I build my cabinet:
- I make a precise cutting plan: it's worthed to spend some time doing this ,
so everything fits well when assembling.
- I go to a lumber hard to have all my panels cut: they have these big wall saw that
cuts very precisely ( With my ability, it's a solution where you get everything
very well cut for a small amount of money). I just make , with a table saw, some
adjustment cut when needed and cut the drivers' holes with a Jasper circle jig and
a router.
- I assemble all the panels with clamps and glue only ( no nails nor screws)
- I use birch plywood (3/4 inch) : 3 panels thick (massive) with green glue.
_important is the planning before having the wood cut.
Old 13th September 2011, 03:26 AM   #27
thaumaturge is offline thaumaturge  United States
thaumaturge's Avatar
I haven't seen anyone here suggest use of urethane (Gorilla, Pro etc) glue. While pricey it will strengthen your joints about 300% while also sealing any air leaks in the joints. Wear gloves while using it as it takes weeks to wear off skin. A quick sponge dampening of the wood before application also helps it work better.
GSM (Good uh.. Stuff Manard).
Doc
Noli timere problematum affigit
Old 13th September 2011, 10:44 AM   #28
I did also mention gorilla glue, yeah it cool, a bit messy, after about a week the stuff is concrete hard. Typically I’ll start with a big side e.g. 12” x 18”, lay that down. Cut the “rips” for the top, bottom, front back, port if it a slot vent. Do the best you can gluing the rips down the 12” x 18” side, let that dry. You’ll want to cut the last side bigger, something like 12 ¼ x 18 1/4”, the overhang is important because the cabinet is probably out of square slightly, etc. Use flush cut router OR belt sander to trim it up, pad sand to a smooth finish is so desired.
Here’s a handy router bit I found, ordered two yesterday: http://www.amanatool.com/routerbits/down-shear-trimmer-47094.html
"Make It So Number 1." --- Capt. Picard, USS Enterprise
Old 13th September 2011, 11:55 AM   #29
marce is offline marce  United Kingdom
MDF, GLUE and nails
A recent thread had some info on joint strength, posted by Cal. Surprisingly the urethane glues came bottom!
Old 13th September 2011, 12:23 PM   #30
- regular woodworking glue is strong enough for me. First, I put the glue and let it
soak in the wood and then I apply a second layer and clamp.
MDF, GLUE and nailsHide this!Advertise here!
FREE and ÜBER HIFI [Nine Inch Nails - The Slip] ak_47_boy Music 7 22nd May 2008 03:10 AM
MDF and Gorilla Glue Consul Multi-Way 23 26th May 2007 01:14 AM
FE127E hole size, Butt joints and using PVA glue with MDF bluegti Full Range 32 19th June 2006 12:53 PM
Liquid nails good enough to hold endplates on sonotube sub? GuyPanico Subwoofers 9 4th April 2005 01:42 AM
