diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Construction Tips (http://www.diyaudio.com/forums/construction-tips/)
-   -   2 8ohms speakers in paralel to 8ohms crossover? (http://www.diyaudio.com/forums/construction-tips/191089-2-8ohms-speakers-paralel-8ohms-crossover.html)
taller4 18th June 2011 05:42 PM
I have 8ohms speakers wired in paralel, could i conect them to 8ohms crossover? what will happened if so? please help.
tinitus 18th June 2011 05:58 PM
hey, maybe you will find some here
http://www.diyaudio.com/forums/multi...crossover.html
Loren42 19th June 2011 12:01 PM
Originally Posted by taller4 (http://www.diyaudio.com/forums/construction-tips/191089-2-8ohms-speakers-paralel-8ohms-crossover-post2610582.html#post2610582)
Simple. It changes the crossover frequency.
A crossover is just an LCR filter. That is, the inductors and capacitors utilize a set impedance to generate a filter slope. If you change any one component (i.e., capacitor, inductor, or resistance of the driver) the filter will change.
You really need to design a crossover from scratch if you make any changes to the drivers.
Resources saved on this page: MySQL 18.75%
