Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 5th June 2011, 08:38 PM   #1
Billyo is offline Billyo  Australia
Default Clamping a hair's breadth
Next weekend I'm gonna start biscuiting, clamping and gluing my first cabinet together
I want the edge of the MDF to stand a little proud of the butting surface so I can route it completely flush, like what has been suggested here.
So I need to offset the biscuit on the butting surface a "hair's breadth" shallower from the biscuit on the edge and then be able to clamp it in 90 degree clamps without that hair's breadth causing a slight skew in the join.
I figured a thin sheet of sheet metal could be used to lay the biscuit joiner on when doing one of the two biscuits, and that same sheet could be inserted between the clamp jaws and the butting surface of the MDF when clamping.
Does that sound like a sensible way to approach this, or is there a better trick of the trade?
Old 8th June 2011, 02:13 PM   #2
Speakerholic
Cal Weldon's Avatar
Use cleats instead of buscuits?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th June 2011, 04:43 PM   #3
kevinahcc20's Avatar
Your approach will work well...you can select your shim material depending on how much you want to leave to trim. If you have some scraps of "Formica" (high pressure laminate) around you will find they are around 0.04" (1 mm) thick which should be plenty to give you a nice clean trim after glue-up. Also it is good practice after machining is done to do a complete dry fit clamp-up. That way you identify any issues before slathering on the glue and you can have the clamps at hand and set to size so the actual glue-up goes smoothly and without drama. Good luck!
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 10th June 2011, 03:50 AM   #4
Thanks Kevin!
Old 17th June 2011, 06:50 AM   #5
Worked like a charm! ended up using the little sample squares of laminate that came from the same place that I bought the MDF. The top of the MDF stood what looked like .75 mm proud of the adjoining face, that was then easily flush trimmed off with a router.
Old 17th June 2011, 12:10 PM   #6
Nice!!!
Fave Amp: Breadth vizion Pass Labs 2 9th July 2010 07:38 AM
Disk Clamping - Which is best ?? poynton Digital Source 32 1st January 2010 04:57 PM
Gluing and Clamping wintermute Construction Tips 6 25th August 2009 03:09 AM
lossless clamping with current sense, how? zilog Power Supplies 5 25th July 2008 11:59 AM
Output clamping diodes:When do we need them??? Leolabs Solid State 13 8th February 2007 06:58 PM
Page generated in 0.09999 seconds (70.97% PHP - 29.03% MySQL) with 10 queries
