Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th June 2011, 09:14 PM   #1
Billyo is offline Billyo  Australia
Default How to make a detachable panel
Hi all,
I'm in the process of assembling my cabinets for a nice pair of floorstanders. I'd like to make the back panel easily removable - preferably without using screws direct into MDF, as I expect that eventually, with numerous opening and closings, it will eventually strip the inside thread from the MDF.
So what alternatives does everyone use for securely attaching a fairly heavy back panel?
Apparently there are specialty biscuits around that allow for it, but I can't find them anywhere (googling gives lots of hits on the Ice Vo Vo type of biscuit and little on the sort of specialty biscuits I'm looking for)
Thanks guys
Old 4th June 2011, 09:25 PM   #2
Have you considered using "T" nuts?
Old 4th June 2011, 11:25 PM   #3
Peruse the McMaster-Carr website, there are only three fasteners known to man that are not in their inventory! (Humor for those from Manchester.) You should be able to figure out what you want to use and then locate it a bit closer.
Old 5th June 2011, 12:44 AM   #4
chlorofille's Avatar
That's an awesome website. I can use their M5 threaded rods to hold my stacked CNC cut panels! Thanks.
edit : Do you know if they ship worldwide?
Sand till the end of time
Old 5th June 2011, 07:12 AM   #5
zman01 is offline zman01  Bangladesh
Threaded inserts with the right length of screws are very handy for this.
Old 5th June 2011, 07:22 AM   #6
Those threaded inserts are exactly the sort of thing that I wanted - I assume that T-nuts are much the same thing, just with a different way of gripping the surrounding material.
Are there any relative strengtsh/weaknesses of each that would be handy for me to be forewarned about? From the looks of it, a threaded insert looks more prone to slipping inside the hole... does it need to be glued in?
To install, I guess I drill a pilot hole through the back panel and into the cabinet where the insert will go, then drill out a large enough hole for the insert or t-nut to fit in.
Old 5th June 2011, 07:24 AM   #7
frugal-phile(tm)
planet10's Avatar
Threaded inserts as shown by Zia are your best bet, It would pobably only take one screwing an unscrewing to screw MDF.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th June 2011, 08:04 AM   #8
dave
Zia?
one screwing and unscrewing to screw MDF... not sure what you mean...
Old 5th June 2011, 08:10 AM   #9
frugal-phile(tm)
planet10's Avatar
Originally Posted by Billyo View Post
Zia?
aka zman01
That is about how many uses you'll get if you try to screw directly into the mdf.
dave
Old 5th June 2011, 02:00 PM   #10
Billyo,
I am attaching a close up of a typical threaded insert - please note that the "nose" of the insert is slightly narrower than the body. For the hole for the insert, make sure it's big enough for the nose of the insert to drop in a few mm but then rest of it is tight enough for the threads to get a grip into the MDF. Also make sure that you drop the insert straight - if it is at an angle, then the whole insert will get screwed in at an angle. When you are sure that you have the threaded insert straight and the threads have a bit of grip so that when you screw it bites in the MDF and starts to go in, use the right size of Allen key/hex key to screw in. Make sure that the insert goes in fully, no harm if it goes in extra 1-2 mm; if a part of it is sticking out, you might not have a good seal for the back panel.
I also suggest practicing on some spare MDF a few times till you get the hang of it.
A tool like the dowel master can be helpful to get the spacing right and screw holes straight.
-Zia
shure e530: splicing a non-detachable cable mattkarikomi Headphone Systems 2 20th December 2010 04:27 PM
anyone here tried to make a panel speaker/dipole tweeter with PVDF films? mondogenerator Planars & Exotics 10 6th March 2010 02:30 AM
Detachable car audio system. v-bro Car Audio 5 9th January 2007 10:32 PM
How to make a durable back panel? tktran Multi-Way 4 24th February 2004 05:41 PM
Page generated in 0.10392 seconds (87.83% PHP - 12.17% MySQL) with 11 queries
