| Construction Tips Construction techniques and tips |
Does anyone know how, where to anodize already anodized aluminum knobs ?
They're black but need them to be gold. I guess stripping off black color comes first. There are anodizing kits online but I don't want to pay an arm and leg for changing the color of small knobs 25mm and 35mm in diameter. Maybe someone has already such a kit at home ? Willing to pay for a good service :-) |
#2 |
It is easy to remove the anodizing, lye will do it. But the black color most likely is a dye used under the finished surface. You are better off starting with natural aluminum. Most folks offer the same knobs in both colors. My anodizer charges $45 minimum. The idea of how to anodize is simple, getting good results is not.
#3 |
YGPM
#4 |
This is what I'm looking for. Have the same amp but black knobs which take away good look.
#5 |
Have you tried contacting them, re; ordering gold knobs?
jeff |
#6 |
Yeah, no answer.
This is an old integrated amp, they ceased production ten years ago. Old but so far I have not been able not find anything better and I went through many. |
#7 |
Check out HiFi DIY Site - VT4C/211 Power Triode
Audio Catalog They have loads of knobs for a few bucks each in many, many flavors. Shipping from Asia would be less than the minimum fee at your local anodizer. Stripping and re-anodizing can be tricky to get a good cosmetic finish. |
#8 |
Just went there and bought what I need. Thanks for the link.
#9 |
sidenote, one can achieve black aluminium via anodizeing.
suposedly if i remember correctly a strong acid will do the trick. //before experimenting wait till someone verifys my memories and recommends an acid// |
| Remove printing from anodized aluminum | cent88 | Construction Tips | 12 | 1st February 2011 01:51 AM |
| Anodized Aluminum Heat Sinks | clm811 | Group Buys | 39 | 3rd February 2009 05:45 PM |
| Pen to write on anodized aluminum / silkscreen | antness | Everything Else | 3 | 8th February 2005 01:07 PM |
| Anodized Aluminum and Glue/Epoxy | Bryan | Tubes / Valves | 22 | 18th May 2004 11:24 PM |
| Page generated in 0.10460 seconds (77.26% PHP - 22.74% MySQL) with 11 queries |
