| Construction Tips Construction techniques and tips |
Hi all !
every times when we mount our little soundsystem, we start debating a lot how we should place the speakers i mean, if i have 4 , sub-woofer in pair, it's better to stack them keeping the speaker near each other, or by keeping them vertical or in some other way ? and why stacked speaker system should go deeper with freq response ? sorry for my bad english! |
#2 |
Audio Engineer
If you are asking should you stack two subwoofers; the answer is no.
If you place them in different locations in the room you will cause less resonant modes in the room and have smoother bass. To find the a good location find a bass heavy piece of music and try moving the subwoofers around. Near the middle of the longest walls is often a good place to start. Offset the speakers in opposite directions on opposite walls. Regards, Andrew |
#3 |
hi and thanks for your reply!
yes i was asking about stacking subwoofers and mid-low unit, we usually play open-air so we arrange them as a "wall of sound" but as i said we don't know how is the best way to arrang them i'll keep your suggestion when the next winter we'll play indoor! |
#4 |
You can try centre clustered in front of the stage, as long as it doesn't interfere with audience sight lines( the stage is high enough) , this way provides good coverage. If you do one stack either side of the stage you tend to get "power alley" which has a peak from both stacks that meets in the the centre of the two and extends outward with corresponding peaks and nulls on either side that move around depending on the frequency being reproduced. It has been suggested with this approach to keep one of the two stacks running 3dB lower to reduce interference between the two.
I have had very good coverage with 4 bass/ mid /high stacks around the outside of the crowd pointing in to the centre. But of course that setup has some fairly peaky areas too
JEREMY M_________________________________ I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ? |
| Stacking Cores | uzernaam | Power Supplies | 87 | 5th January 2011 02:04 AM |
| Stacking Opamps?? | fmak | Digital Source | 4 | 13th August 2004 07:02 AM |
| “Stacking” Toroids??? | Jan Dupont | Parts | 2 | 10th June 2003 09:47 AM |
| Core Stacking | fr0st | Parts | 1 | 20th March 2003 09:07 AM |
| Stacking toroids - Ok? | harvardian | Solid State | 23 | 11th September 2002 05:40 AM |
| Page generated in 0.07726 seconds (70.67% PHP - 29.33% MySQL) with 10 queries |
