| Construction Tips Construction techniques and tips |
In anticipation of multiple removals of my drivers I made these brackets out of some 1/8" thick steel strap I had lying around the shop. The tapped hole is 8-32 because that's what I had. For strap this thin you'd want some pretty fine threads. You could change the size and configuration to suit your needs.
001.JPG 003.JPG |
#2 |
Try hurricane nuts!
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy! |
#3 |
Custom Title
plus glue, to firm up the wood around those tiny little fastening fins. Woodglue and superglue and urethane glue all work, but I'd stick to the first 2 as I could see urethane expanding out and getting on the outer threads (haven't used that, but have used the other 2).
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#4 |
frugal-phile(tm)
The Admiral Tunnel Reflex fronm the 60s & 70s had all their drivers mounted with such a fitting.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Depending on the application, hurricane nuts have to have too large a hole and would weaken the baffle as well as stick out past the edge and the whole turning when you don't want them to turn thing. They also couldn't be used if the back of the hole is beveled. They have their place though but so do my brackets.
#6 |
| Driver mounting question | Robertburchell | Full Range | 4 | 17th October 2009 07:33 AM |
| Mounting the driver | Ant_222 | Subwoofers | 1 | 4th August 2006 01:48 AM |
| Driver mounting. | 2litre | Multi-Way | 9 | 21st January 2006 07:04 AM |
| better driver mounting | mike | Multi-Way | 26 | 17th December 2004 09:56 PM |
| Best method for cutting driver holes? | dc | Multi-Way | 16 | 29th May 2002 12:27 PM |
| Page generated in 0.07026 seconds (82.56% PHP - 17.44% MySQL) with 11 queries |
