Construction Tips Construction techniques and tips
Easiest cabinet design for full range driver
Old 25th May 2011, 04:39 AM   #11
503Timber is offline 503Timber  United States
Originally Posted by planet10 View Post
Clayton,
You have the FE127e, which althoy it looks like the FE126 from the front is a different beast and will happily work in a BR. Hopefully the FF125wk will fill the role of the now discontinued FE126.
dave
Not to thread snipe here but what current Fostex model is nearest the FE127E? I have a friend with the 126's and you are right....different beasts.
Old 25th May 2011, 04:44 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Mar-Kel70 gets almost as low as halfTower, but more finese, not near as easy a build.
More finese thru the mid-top and more capable of doing a disappearing act.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th May 2011, 09:50 AM   #13
zman01 is online now zman01  Bangladesh
BTW Dave, is there something called a Twin Mar-Kel 70? I know there is a Twin CHR-Ken.
As another newbie I feel Half-Towers would be a nice easy build. I would dare say a Pensil without the bracing looks simple too.
-Zia
Old 25th May 2011, 10:04 AM   #14
frugal-phile(tm)
planet10's Avatar
There are Twins of all of them, even if i haven't drawn them A Twin A12 might be pushing it, but i thot a Twin A10 would be but Toppsy is very happy with his. And there is always the option of making it 1.5 way.
dave
Old 25th May 2011, 11:32 AM   #15
Dave,
Toppsy's speakers look simply awesome... I can see them with my eyes closed . Colin says that they play rock music very well. I always used to think it was a Twin CHR-Ken - then learnt those are 2 x Alp 10s! (probably 1st gen).
Twin Alp 12 would be interesting indeed... maybe once Alp 12.3 comes out with most of the upgrades of the "wishlist" (i.e. paper cone, more bass, square voice coil among others) you can do a POC?
Regarding Twin Alp 10 Kens doing great with rock music... after playing with Castle MTs if I have some obervations/hypothesis about FR and loud/noisy rock/metal - will share.
Excuse my newbie ignorance, what are you refering to as 1.5 way?
-Zia
Old 25th May 2011, 07:23 PM   #16
terpkev is offline terpkev  United States
Dave, the mar-kel70 looks do-able for me. Except for one thing. Where the driver is mounted. It looks like there is an angled cut, plus flush mounting. What tools/techniques do u need to accomplish that? Is the inside angle cut absolutely necessary? Also are all the other angled cuts just 45 degrees?
Thanks for the help!
Kevin
Old 25th May 2011, 07:52 PM   #17
frugal-phile(tm)
planet10's Avatar
Originally Posted by zman01 View Post
POC?
A TLA i am not familiar with.
Using 2 identical drivers and rolling off the top end of one of them. Used primarily as a way to compensate for bafflestep, but also gives more cone at low frequencies & more of a point source at hi-frequencies.
Amplifier output impedance is an important consideration.
dave
Old 25th May 2011, 08:01 PM   #18
frugal-phile(tm)
planet10's Avatar
Releiving the back of the cut-out is important for minimizing boxy/cupped sound in the midrange. It can be acomplished using a big rasp. The fancy & elegant ones shown, are usually accomplished with a specific router bit.
There are some drivers you can get away with no bezel rebate. Most of the Fostex for instance. But a deep circular bezel really benefits from being flush.
The rebate is usually accomplished with a router, But it can also be accomplished by flush mounting the driver and then building up the baffle with 1 or more layers of material (it doesn't even need to be wood. Corl or dense felt would work. The layers on top would only need a round hole cut in them.
The big champher is 45 degrees and usually cut off the built box with a big table saw. But people have done it with a skill saw, or even in one case with a hand saw. Lots of sanding usually required. The Classic GR versions were done to get the same alignment with an easier build.
dave
Old 25th May 2011, 08:53 PM   #19
Dave,
POC is Proof Of Concept. I keep on forgetting what TLA stands for, LOL - Though I try avoiding, TLAs seem to creep in.
-Zia
Old 25th May 2011, 08:55 PM   #20
dave
Glad I asked this question - useful learning for me.
And Output impedance - I have had some first hand suffering recently.
-Zia
Easiest cabinet design for full range driverHide this!Advertise here!
Best Full range drivers under 100 for a horn loaded cabinet? Bill poster Full Range 38 1st March 2011 12:42 AM
full range drivers in a sonus faber style cabinet. would this work? blrh93 Full Range 17 16th January 2011 01:25 AM
Full range and/or High Efficiency possible in small cabinet? Seraph Full Range 29 19th June 2007 02:13 AM
full range driver array design Salsero Full Range 0 24th November 2005 04:04 PM
Full Range Driver PassFan Full Range 4 18th November 2003 04:28 AM
Copyright ©1999-2017 diyAudio
