Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 16th May 2011, 10:54 PM   #1
Default 2 way passive crossover
Hello,
I would like to build a 2 way passive crossover for a pair of 2 loudspeakers system made in USSR (TENTO) a few years ago. I don't have the original speakers, nor the crossover inside so i decided to build one. The speaker cabinet is very nice and i think it was well calculated.
I have two 4 ohm speakers inside:
YDD 200 LPP
DIAM=200mm D. Magnet=100mm Putere M=150W
Frequency=55HZ-5KHZ
Senz=90dB Imped=4ohm;
output 75W
and this one:
Untitled
As you have noticed, i don't have a tweeter but a midrange speaker. I really do not want to use a tweeter because i don't like high pitched sounds. This speaker will reproduce quite well higher sounds....
I'm wondering what filters should i use? 2nd order or 3rd order? I have read that there is not much difference between 2nd order and 3rd order. The big difference is between 1st order and 2nd order.
However, i read about 2nd order here :
Second Order Passive Crossovers, 12 dB per Octave
and about 3rd order here:
Third Order Passive Crossovers, 18 dB per Octave
Building the inductors is very easy, i just have to specify the inductance
Shavano Music Online - Cross-Over Network; Air Core Inductor Calculator
Calculating the right inductance is difficult for me. This calculator makes things very easy, all i have to do is specify the speakers impedance and the frequency.
Passive Crossovers, Capacitor and Coil Calculator
The problem is i don't know what to introduce in the frequency field. I would like to get the best from these speakers. A three way crossover would have been easier. I think the 2 way is difficult because it's a compromise. It uses 2 speakers for the whole range instead of 3 separate speakers like in a 3 way system.
Old 17th May 2011, 07:06 PM   #2
Passive Crossover Network Design
you need to gain way more info about those speakers.
Passive 3 way crossover hamedfazelm Multi-Way 2 14th July 2010 01:53 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Passive crossover Twisted Parts 0 19th January 2004 08:32 PM
About passive crossover stefanobilliani Pass Labs 5 2nd August 2002 07:39 PM
Page generated in 0.09218 seconds (71.07% PHP - 28.93% MySQL) with 10 queries
