| Construction Tips Construction techniques and tips |
Hey, I seemed to have lost my other account and cannot retrive it so I am posting under this name.
Ok, I am building a set of speakers and I have no clue on veneering. I don't have a vacuum to use to bond the veneer , so I wondering if anyone could point me to any good web pages on veneering or give me and advise on how to go about it? Cheers |
#2 |
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas |
#3 |
Searched the web for weeks and I have seen that thread and many others on AVS. Just wanted to see if any one had any info that might not be doing the rounds on the interweb or tucked in a little corner of their PC.
#4 |
just another
I found this document very helpful http://www.woodveneer.asn.au/downloa...ers_inlays.pdf
couple of tips. Cut with a stanley knife rather than a veneer saw, I bought a veneer saw but it was useless. spray the veneer with a mix of glycerine and water (10% glycerine from memory) and place between boards with brown paper to flatten (and soften) the veneer before applying. Allow to dry for a few days changing paper as well. If you use PVA glue make sure the ambient temperature is not too high or it will set very fast! I made the mistake of doing one of the panels in 30+ deg heat. Get lots of clamps see picture... ![]() Tony. |
#5 |
wintermute, how did you ensure you got the grain straight?
cheers |
#6 |
This should help.
The first time out of the gate you may consider the PSA products. Joe Woodworker - Woodworking, Vacuum Pressing and Veneering Information Website
Laughing up the wrong tree |
#7 | |
just another
The result was pretty good I thought This is the best pic I have of the grain matching, which was taken before they were oiled. ![]() edit: one thing I didn't mention before,was that I used a rolling pin to ensure everything was flat before putting the upper caul on and clamping. I used a paint roller to apply the pva glue to the box surface before placing the veneer on, and had a damp cloth handy to wipe up any over runs quickly. Tony. Last edited by wintermute; 23rd October 2011 at 10:13 AM. Reason: add some additional notes. |
#8 |
Man that come up wicked. I hope I get my speakers to look that good
#9 |
I used PVA glue also, although I had a different approach. It worked extremely well. Titebond 3, rolled both surfaces, let dry then Iron. Its still looking perfect and you cant tell where the seams are. Do a search for "Curved Thor's" if you care to try this method.
Almost forgot, I used an exacto knife with a new blade to cut the edges of the veneer down to within 1/32" flush then sanded with a block wrapped with 400grit paper.......smoooooth. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. Last edited by Renron; 1st February 2012 at 03:09 PM. |
#10 |
Nice job Winter!
Let me preface this by saying I was a professional furniture and cabinet maker for a long time ![]() Winter's first photo shows a good setup for home veneering. You need lots of clamps and a thick, flat, rigid platten to evenly distribute the pressure. I personally would not recommend ironing on as Renron has done, no offense man Though it can work, it can also be very difficult to do. It is easy to scortch the veneer, the veneer will shrink, if you don't do it right the veneer can crack, etc, etc. I realize doing curved surfaces at home can be hard w/o a vacuum bag, but you can use flexible but rigid plattens (1/8" masonite, 1/4" mdf) and a layer of rubber between the veneer and the plattens to distribute the pressure for clamping.Yellow glue (PVA) works perfectly fine for veneering, as do polyurethane glues like Gorilla Glue. As several have mentioned, use fresh razor knives to cut veneer, not saws. I have never flattened veneer with glycerine, even really old veneer. If it is really fragile (burly claro walnut that is 50 years old) it might be nice, but a warm water mist works fine to. If you use polyurethane glues the water makes it set better, PVA glues will still dry fine but may take longer. PVA glues are water based and I have often thinned thicker yellow glue for veneering. I used to work at a place that bought industrial PVA by the 5gal pails. Great for soldwood glue-ups but a little thick for veneering. Thinning 3-5%-ish with water made it usable. A couple tricks can be used to keep the veneer perfectly positioned for cases where you are trying to match the grain as Winter has done. You can simply let assemble the parts and let the glue begin to setup with only a slight amount of weight. Essentially, the glue will allow the parts to slide around for a few minutes (temperature and how heavy you applied the glue dependent). The moment they stop sliding around easily, make sure you slide the parts to the proper alignment as you apply pressure. This method is easiest to mess up and miss your window. Second, you can simply use blue painters tape (not white masking as it is to sticky to remove after it is pressed) wrapped tightly around. Using tape in each direction at the corners and every 8-12" in the middle will prevent the veneer from moving. This is the easiest and relatively fool proof most of the time. Last method is the most foolproof but longest to setup. Place the veneer face down on a flat surface and place the substrate on top of it. Use yellow, white or hot-melt glue to attach small wooden blocks (1/4"x1/4"x3/4" long are plenty large enough) to the veneer and tight to the edge of the substrate. Let dry and then use these to align the veneer for gluing. Glue should be applied evenly with a hard rubber roller, like is used for hobby printmaking. larger surfaces (like whole sheets of plywood) can be done using black foam rollers. Apply enough glue to completely cover the substrate surface without holes or dry looking areas. If I had to guess, Id say the the thickness of yellow PVA glue applied (use general purpose stuff here, not fast set, outdoor, water-resistant, etc) would be about the thickness of 1-2 sheet of good quality paper-towel. Never thought about it before, I just know how much looks like enough ![]() Always start by applying modest pressure from the middle of the panel first then work your way to the edges. The thicker your platten the fewer clamps you will need but more is always better. WinterMute has just about the right amount on that. Be careful about already glued up parts though as the panels may no longer be flat. Check with a really good straightedge and flatten with a large block of flat wood (say 4'x12") wrapped with some 120 sandpaper. Sand all directions until the whole surface if flat, be careful you don't round the edges. Any rounding of edges, no matter how slight, will create voids where the glue (which has no gap filling properties at all and will soak in) will not make a good bond. Similarly, when clamping something up, be sure you are not somehow flexing the box so as to make the middle of the substrate bow inward and create a pocket in the middle. Finally, use 2-3 layers of newsprint between the veneer and the platten or you will glue everything together forever Been there <sad face>.Final trick: if you want all 4 corners to match as Winter did, you need to use two consecutive sheets of veneer flipped so that the two mating surfaces are on the outside, then imagine opening them like a ziplock bag. Did that make sense? When I say flip, imagine one short grain edge is a hinge and pivot one sheet all the way around on that hinge. This puts the original "insides" of the sandwich now on the outside and all edges will perfectly match visually providing your keep your overlaps the same. Nice way about this is that you can leave as much overhang as you want (say to glue on alignment blocks) and as long as you leave the same amount at matching edges, the veneer will still perfectly line up
| DIY horns get veneer | Wardsweb | Multi-Way | 44 | 19th December 2011 04:05 PM |
| DIY center with ribbon, any tips? | 4real | Multi-Way | 37 | 9th October 2004 11:10 PM |
| Anyone have tips for DIY caps? | JoeBob | Parts | 6 | 30th January 2003 02:22 AM |
| Page generated in 0.12404 seconds (83.16% PHP - 16.84% MySQL) with 10 queries |
