| Construction Tips Construction techniques and tips |
#11 |
I generally work with paper backed sheet veneers, and the iron-on method works like a charm.
After careful layout and marking for grain pattern matching/wrapping, trim slightly over sized, apply a light coat of slow tack set yellow or white PVA glue with velour paint roller to each surface and let dry to touch ( 10-15 minutes). Then align pieces on pre-marked panels, and apply even firm pressure with clothes iron set to high. Don't worry too much about scorch marks - they'll sand out. Trim all edges with razor knife, 2" chisel or plane iron before proceeding to next panel surface. Use masking tape to prevent glue contamination when preparing adjacent surfaces. I've also used this method to reveneer small panels, turntable bases, etc, with solid wood (i.e. no backing) veneers. So far the only part I've found a bit trickier is the cross grain overhang trimming - without the flexible paper backing, the solids are much more brittle and can splinter - "sawing" gently downwards with a chisel or plane iron seems to work best here.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#12 |
Forgot about the paper backed veneers. Those are easier to iron on, but then you get the paper line at the edge. I still prefer regular veneer and small areas are easy to clamp since they require few clamps and smaller plattens.
I should also mention that if you have boxes with butt joints rather then mitered corners, the seam usually will transfer through. In that case, you can first veneer with low grade veneer having the grain perpendicular to the final veneer, then sand flat before final veneer. You can also use a stiff pressed "paper" made for this purpose, again sanding flat before final veneer is applied. These two methods will prevent the seam from telegraphing through later, or at least minimize how bad it happens. |
#13 |
That multiple clamp pic is priceless.
#14 |
That's the press method, could use weights if short on clamps. Not the fastest way to go, but it works and can use regular glue.
#15 | |
#16 |
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
The NBL veneer from formwood is great. works like paperback and the edge is not noticeable.
NBL (No Black Line): FormWood Industries available here Two-Ply Wood on Wood Veneer Stock List Most of my veneering is done with unibond two part glue and a vacuum press. for more "production" jobs contact cement works great. It seems to be the standard in cabinet shops around here. The trick to contact cement is sticks. When the glue is dry on both surfaces and you are ready to bond the veneer cover the substrate with sticks and put the veneer on them. Then remove the sticks from the middle out pressing the veneer down as you go. This lets you get the veneer lined up and pressed with very little drama .
http://www.evancotler.com |
#17 | ||
just another
and I was wishing I had a few more too don't underestimate how many clamps you need if doing it that way! Quote:
Tony. |
| DIY horns get veneer | Wardsweb | Multi-Way | 44 | 19th December 2011 04:05 PM |
| DIY center with ribbon, any tips? | 4real | Multi-Way | 37 | 9th October 2004 11:10 PM |
| Anyone have tips for DIY caps? | JoeBob | Parts | 6 | 30th January 2003 02:22 AM |
| Page generated in 0.08873 seconds (86.44% PHP - 13.56% MySQL) with 10 queries |
