Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 24th April 2011, 11:27 PM   #1
Default Help with quickie finish blemished mdf
So i have a 5 day easter weekend, so i thought he ill get by 84" bib boxes built. Normally i make the front and back a hair bigger then the sides so i can just just sand them flush later. Well with this long of a speaker it didnt work out so some of the sides stuck out a 32nd/64th inch and almost impossible to sand flush without getting wavy. To compound the fact is that my peel and stick veneer is only 2ft wide and not the standard yard (are you UK people crying yet?) so its going to take 3 rolls for 2 speakers, and odds are look like hell.
So is there a quickie finish i can throw on these in 2 days? Im just building them for work but they need to have some boss approval factor.
Lets say i get holes filled and the seams as close as i can, and seal the whole thing with 50/50 pva glue/water. What could i finish them with that wouldnt show the oopsies and look some what decent for like 30-40 bucks for both (say the dimensions are 8ft by 1ft by 1ft)?
Old 25th April 2011, 12:02 AM   #2
Can you glue some sort of fabric on the box? Perhaps a vinyl "black leather" cloth. I am not sure what they call it in the UK.
Old 25th April 2011, 01:50 AM   #3
sofaspud's Avatar
yeah, the speaker carpet for covering cabinets, mostly used for car and pro audio boxes. On a lean budget I've found material at the fabric shop that did the job.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 25th April 2011, 02:53 AM   #4
jackinnj's Avatar
2 days? Best bet for dealing with holes and seams is Bondo -- then for a finish go to your NAPA store and get a automotive primer and finish, IF they'll sell it to you. I've used the DuPont stuff and it's first rate.
and wear a mask -- Sears and others have them rated for the organic solvents used in auto finishes.
Old 26th April 2011, 08:34 PM   #5
joe58 is offline joe58  United Kingdom
How about making a simple frame to fit over the whole speaker and getting some speaker cloth, any colour you like and covering the frame(paint the whole cabinet a flat black for no reflections. Simply slot over and you have a professional look speaker. Theres them Gallo speakers which are covered by a frame and B&O's are always completley covered. Simple.
Old 26th April 2011, 08:37 PM   #6
Gallo Reference.
Old 27th April 2011, 12:06 AM   #7
Ended up with the carpet idea and metal corners since they will be moved around alot.
Ya Joe i did something similar with my home setup. It wouldnt have worked at work because they would be almost impossible to move without damaging the grill.
https://sites.google.com/a/dslextrem...peakers/db1661
Fostex leftovers singles, blemished, wierd planet10 Swap Meet 1 15th November 2010 06:22 PM
something to finish mdf paulfk Multi-Way 14 14th March 2009 02:04 PM
MDF Finish bjackson Multi-Way 26 3rd June 2005 11:41 PM
MDF + Clearcoat finish... bibster Multi-Way 11 15th September 2004 10:41 AM
Simple finish to put on MDF speaker enclosures? vision Multi-Way 5 30th August 2001 06:30 PM
Page generated in 0.08424 seconds (79.95% PHP - 20.05% MySQL) with 10 queries
