Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 1st April 2011, 05:12 PM   #1
Default Parametric EQ project
Im currently undertaking a self led university project to explore the possibility of a portable, battery (pref 9v) powered 3 band parametric EQ to be used by a soundman on location when recording vocal interviews.
Im struggling with adapting the parametric EQ design on this webpage:
Spectrum Analyzer and Equalizer Designs
I have a prototype of the unit built and cant get all aspects of the filter to work together,
I need to know a few things;
1.) Is this design adaptable and if so would it be possible to cascade 3 of these filters.
2.) how do i handle power issues? im of the understanding that a 4.5 volt supply is required for the IC's but i have a feeling im going about this the wrong way which is the source of my issues.
3.) any tips on simulation as im currently using LTspice and having trouble simulating a pink noise test signal.
Any help or any additional pointers would be very much appreciated as i seem to be circling the same issues.
Old 1st April 2011, 05:27 PM   #2
Mooly's Avatar
All the opamps in these circuits need a split supply i.e. a plus and minus rail with centre ground. The opamp data sheets will tell you the minimum supply.
A simulation free zone. Design it, build it, test it.
Old 1st April 2011, 05:42 PM   #3
Boofers is offline Boofers  Canada
Don't use a TL074, there are so many better op amps out there. You can get decent op-amps for just a few bucks.
You could use two 9V batteries for your rails to get a +9V and a -9V rail. Check your op amp datasheet for voltage rail options.
Old 1st April 2011, 11:38 PM   #4
ok thanks for the tips, 2 batteries is a possibility, another noob question how do i pull a negative voltage from a second 9v cell? prefereably without the use of another IC as uni is closed for the weekend and i was hoping to get this running over the weekend
Old 1st April 2011, 11:50 PM   #5
Think in the "inverse". Merely ground the positive (+) terminal of the 9v battery, and run the negative (-) terminal to your -9 volt rail. No need for any IC's...... this is very straightforward. When you do it, remember that all voltages are "referenced" to your ground..... Your + battery gives you +9 volts, while your - battery will give you -9 volts.
Easy one......
Old 2nd April 2011, 07:51 AM   #6
Mooly's Avatar
Or to draw it,
Old 2nd April 2011, 12:22 PM   #7
IMHO there is nothing wrong with the quality of the TL074 for your aplication or any audio aplication for that matter.
However, when you have as many as 4 or 5 or more in a circuit they may not fair well on battery power time.
You might want to consider a low power opamp version for your final product.
Below is a data sheet of your average 9v battery.
A TL074 has an average power dissipation of around 200mw and can be as high as 680mw when pushed hard enough.
jer
Old 2nd April 2011, 01:43 PM   #8
jer is right. The TLO7x/08x are great. I allways liked the built-in white noise generator. E
Old 2nd April 2011, 01:54 PM   #9
this is all great info thankyou very much, i have my dual battery supply sorted and am not bothered about power consumption at this stage as its only concept proving. im using a minirator and minilyzer to generate a pink noise test signal, i have gain control and cut/boost control but no filter shaping, i think im making a silly mistake when interperating the diagram, the "earths" on the diagram (white arrows) are where my confuson is, do i connect them to the ground (0v) from my batteries or connect it to the non hot line from my minirator?
Old 2nd April 2011, 02:00 PM   #10
Mooly's Avatar
The white arrows all go to the zero point (0) in diagram in post #6 That point, the 0, is then reffered to as ground and becomes the point from which all voltage and signal measurements are referred to.
parametric EQ placement perlmonkey Solid State 1 30th January 2011 12:12 AM
high Q eq or parametric qweetz Parts 0 14th September 2010 09:31 AM
semi parametric eq reap461 Parts 5 4th December 2008 08:56 PM
Phoenix Systems parametric EQ Slab Everything Else 1 16th February 2005 04:52 AM
Page generated in 0.11301 seconds (77.46% PHP - 22.54% MySQL) with 11 queries
