| Construction Tips Construction techniques and tips |
#51 |
Butt joints and drilling end grain didn't seem the right way to do things when I put my speakers together. Butt joints can a pain to align and clamp. Whilst drilling end grain on MDF, even with pilot holes is a lot of work and the MDF can bulge.
I instead used biscuit joints. Once I'd played around with a biscuit joiner for an hour or so I realised that I could produce very strong joints that aligned perfectly and stayed align when I clamped them up. The speakers were build with an inner 18mm MDF carcase, cross braced, all biscuit joined using PVA. Wrapped around the inner was another 18mm MDF box, again biscuit joined but epoxied together and to the inner. Heavy and very strong. And a couple of pictures... ![]() ![]() ![]() The final speaker, one of two ![]()
H&Ks Garf. |
#52 |
Wow, great result!
How do they sound? what design are they?? Cheers
If you keep digging in the garden of failure you will eventually find success
#53 |
Speakerholic
Not if you install cleats before assembling the panels.
Really nice speakers BTW.
#54 |
They sound pretty wonderful. The combination of a 10" bass unit in a sealed box and the mid plus tweeter on an open baffle is the right combination for me.
I've put together a pdf with details and build notes BoM - final-revamp-1.pdf I can't take credit for the design. I just 'smoothed' the shape and swapped the tweeter. Cheers
H&Ks Garf. |
#55 |
Cheers
A pair of these might just have to go on the project list! Thanks for such detailed info, It may take a while but will keep you posted on progress. In the mean time I have joined PFM and will look into James (fellow Kiwi)work. Cheers
#56 | |
The original built thread is PFM Special - a simpler and more affordable DIY loudspeaker design - pink fish media My build is on the end of James's design posts. Oh and welcome to PFM. James has built a few speaker designs which have been documented on PFM, try searching for 'Ergo'.
H&Ks Garf. |
| Help to assemble a broken louspeaker.. | coldcut | Multi-Way | 3 | 23rd September 2008 01:41 PM |
| Would i be able to assemble my own crossover? | PoorSound | Multi-Way | 10 | 11th February 2008 10:02 PM |
| Please help me assemble my UcD180 stereo-amp | zhai | Class D | 6 | 6th December 2006 05:52 AM |
| Need to assemble a clock. | Maples | Everything Else | 3 | 28th November 2004 05:19 AM |
| MDF/Sand/MDF cabinet details | Petter | Multi-Way | 25 | 16th April 2002 02:10 PM |
