| Construction Tips Construction techniques and tips |
#11 |
A stereo microscope is the best thing I've used. I happened to find this via Google: C & A Scientific SMD-04 - I-Explore Scope. It ain't a Leica, but it looks like there's plenty of room to work, and the price beats the $65 loupe.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#12 |
#13 |
At work, I generally use one of the arm-mounted circular fluorescent lamps with a central magnifier for both through-hole and SMD work. I'm pusing 60, but this setup usually gets the job done. When I want to look for solder whiskers or really check a SMD solder joint, I'll resort to using a binocular microscope - you want one that is wide field, relatively low power.
#14 | |
I bought a "daylight company" illuminated magnifier a few years ago. This is the sort of thing used in professional repair. The image is large at 7 inches and the most important thing is the focus field is clear edge to edge. This means that if you wear "reader" lenses the only impediment to a good view is whether the lens is clean on both sides. P |
#15 |
I did buy them. I have not yet used them to assemble an SMD PCB, but my impression is that the focal length is just a little bit too long to work comfortably when seated at a bench. I probably should have realized that because they are designed for dentist, who usually works from a standing position. It may be that I just have to get used to them. I'm kind of used to working hunched over using an Optivisor.
#16 |
Dental loupes is a magnification device which is used to see the objects more close, they are used during surgeries or during dental checkups. Its fine design yields higher power and high definition. It is lightweight and comfortable to wear and easy to adjust. It crystal clear glasses ensures clear vision.
| Will this amplifier work with this subwoofer?? How would the wiring work? | hd2008 | Car Audio | 0 | 20th March 2011 08:57 PM |
| use of SMD components? | lanchile | Solid State | 7 | 26th September 2010 12:33 PM |
| Surgical Silk For Sale | Clack | Swap Meet | 3 | 9th April 2009 04:15 PM |
| headband magnifier for SMD work | gychang | Parts | 4 | 1st November 2007 03:28 PM |
| Better than LM329 and SMD | peranders | Parts | 1 | 1st June 2004 09:17 AM |
| Page generated in 0.08606 seconds (75.69% PHP - 24.31% MySQL) with 10 queries |
