3 Way Loudspeaker Designing - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 17th March 2011, 06:10 AM   #21
picowallspeaker's Avatar
Usually in three ways ,spectrum is divided in 3 bands : 300 (500)-3000 (5 K) Hz
or in a two way 1.5-2.5 KHz is where the tweeter is crossed . Midrange unit then plays the voice and all instruments in a 3 way ,and the character of 'colouration' in the low end of the mids ...about 300 Hz !??! which happens to be at crossover frequency . Thus a ported box for the mid ...and a different slope and freq. cut and steepness between Woofer and Mid ...!??!
Old 17th March 2011, 06:10 AM   #22
Jameslc is offline Jameslc  Australia
Originally Posted by tinitus View Post
will the 6" play down to 50hz, and have no xover ?
maybe try to sim the closed version with slightly smaller volume
rolloff will be a bit lower, a nicely 'rounded'
remember that it should be 6db down at xo point to woofer
woofer should likewise be 6db down
maybe also take a look at xmax figures
so where should be the Midranges line like it is now or lower Woofers are green and Mid is yellow
Old 17th March 2011, 06:14 AM   #23
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Originally Posted by Jameslc View Post
so the Midrange is only helping the tweeter with the below 100hz stuff i think that is right?
I'm not quite sure I understand what you mean. . . but no need to port the midbass drivers if you are crossing them over to the woofers, especially if it's a passive crossover.
Ported midbass drivers won't be needed with those big woofers you are using and would likely only make the bass worse.
Using the midbass drivers in a sealed/closed volume will give you better transient response, better power handling and a flatter less reactive impedance.
Old 17th March 2011, 06:20 AM   #24
ok yeah i was a bit confused with the 6db down and the xo post earlier anyway i will
have a go at building them after doing all these changes i have my work cut out to work out how many sheets of MDF i need
with the post earlier about floor bounce does that mean will the woofer sound arrive later then the midrange if so do i just move the woofer down the box to make the sound arrive the same time
Old 17th March 2011, 06:26 AM   #25
AEIOU's Avatar
so should i move the woofer down near the bottom of the box?
Well, it kind of depends on where you crossover them, but generally yes.
Old 17th March 2011, 06:32 AM   #26
AEIOU's Avatar
No.
There is direct and reflected sound from both the midrange and woofers, however since bass wavelengths are so much longer bass cancelation can occur when the direct and reflected sound waves arrive at your ears at different times, i.e. out of phase.
You'll almost always hear the midrange before the bass to begin with just because the acoustic center of the midrange driver is closer to the plane of the baffle than the woofers acoustic center is.
Old 17th March 2011, 06:33 AM   #27
ok i think i have got it perfected
unless there is somthing else i need to improve
but i am going to have to think of different design because i don't really like the look
Old 17th March 2011, 06:44 AM   #28
AEIOU's Avatar
Do you listen to music sitting or standing?
Try not to have your midrange and tweeter up too high or the sound from them will be shooting over your ears/head.
Old 17th March 2011, 06:47 AM   #29
usually i am sitting in a bean bag about 4 to 5 feet away
Old 17th March 2011, 06:49 AM   #30
anyway thanks for all the help everyone i am going to have to play with the design on how it looks and i will post the finished product when it is finished
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 130 14th June 2016 11:21 PM
Designing a loudspeaker intended to use with a digital crossover Pagnol Multi-Way 16 8th April 2010 11:48 PM
help designing my 2.5-way edjosh23 Multi-Way 8 26th August 2005 06:40 PM
PLease help designing my first sub. JiggaD369 Subwoofers 119 5th May 2005 10:58 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 12:46 PM
Copyright 1999-2017 diyAudio
