Deicated Electronics Work Space - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 3rd March 2011, 09:37 PM   #1
zdavesf is offline zdavesf  Canada
Default Deicated Electronics Work Space
*Dedicated Electronics Work Space
Hello All,
I have looked over and viewed a couple topics already on this forum but thought it would be nice to get some more input.
I am currently finishing my basement off in my home and I have decided that I am going to have a dedicated electronics work space. The room is about 11' x 13' all for me (yes i know im lucky). I spend most of my time doing audio and programming related projects (usually together) i still just get my boards made online, but may looking etching myself. My thoughts are to have benches around all the walls and do a rubber tile flooring so i can roll around easily on my chair (possibly do esd wax as well, have to look into price). I was thinking to divide the equipment into three areas: Programming, breadboarding, solder/mechanical. I havent done electronics in over a YEAR!!! trying to finishing building my house... finally just about there
I will build shelving 16" or so above the desktop to put equipment on and yes i will make it sturdy. I have already wired one dedicated 20amp circuit to the room and there is another 15 amp common circuit with the other bedroom so power should be ok. I installed 3 recessed lights above the "breadboarding workspace" and will still have a magnifyer light as well.
if any one has any suggestions of what they would do with the area, or things they just cant live without, by all means please share your input . Money is not a huge concern (as far as constructing the workspace) new equipment will come as i find a need/use for it.
My current equipment consists of :
-programming/cad PC
-Sever PC (for the whole house)
-lab PC (for my USB scope, audio test files etc...)
-2x22" monitors for CAD PC
-1x17" monitor for the Lab PC
-benchtop PSU (2x30VDC 4amps each)
-function gen
-function counter
-analog scope
-digital multi meters (just cheap kind, i need a good benchtop one)
-test amp/speakers
-solder rework station (vaccum and hot air)
-soldering iron
-parts bins
-tools
here are some drawings of my idea's
we all have to start somewhere...
Old 4th March 2011, 01:53 AM   #2
theAnonymous1's Avatar
Dedicated Electronics Work Space? I call that "my apartment". Can't remember the last time I was able to eat a meal at my kitchen table.
Old 4th March 2011, 01:56 AM   #3
Deicated. That when you're sitting in front of the bench, right?
Old 4th March 2011, 02:03 AM   #4
You will need more power! Always do. I dont think I would combine Soldering and Mechancal thay dont mix well. Keep Mechancal stuff (drill chips) away from the electronics if you can. Mix prototyping and programing, put drilling on the other end and soldering in the middle. Vary nice by the way. Andy
Old 4th March 2011, 02:18 PM   #5
Thanks for the input everyone. I guess what i meant by "mechanical" is where i demo/salvage equipment. No drilling yet (I have a garage for my metal work and box building and the real dirty stuff) That being said I may start making pcb's and drilling... better change it up a little. Sorry about the spelling, thats why i do electronics and not journalism
Old 4th March 2011, 02:44 PM   #6
Boofers is offline Boofers  Canada
With lighting, the rule I like to use is "Too much is just enough."
What about putting in some sort of fume hood for solder fumes. Could even be the kind you put over your stove.
Where's the beer fridge?
Old 4th March 2011, 03:06 PM   #7
yes, i forgot about that. Ya i will be drilling an exhasut fan/range hood or one of those 5" moveable tubes on a mount with an inline fan in probably (it was my original intent) Right now they way i have it drawn there is a window above where i will be soldering, i have a window mounted fan which works ok... good point. as for beer fridge... i will have bar downstairs about 10 steps from this room, that should be close enough
keep the ideas comming, cause once its built i am not going to have the ambition to add to it, i need to get back to actual circuits and wortk on my integrated amb with usb/iphone control!
Hello from Space City U.S.A. River757 Introductions 8 22nd November 2010 12:20 AM
Any suggestions on setting up a dedicated electronics work area at home ? Ohighway Equipment & Tools 24 16th September 2008 11:41 PM
I need space. kiowamec Multi-Way 3 22nd May 2006 06:26 AM
lost in space JRKO Introductions 2 26th December 2003 11:44 PM
Not enough space? WhtCastle Everything Else 7 28th November 2001 02:46 PM
Copyright 1999-2017 diyAudio
