Construction Tips Construction techniques and tips
layered MDF vertical array
Old 23rd February 2011, 09:45 PM   #21
nulesus is offline nulesus  United States
I just realized that I may have to expand the panel size to 16"x48" The baffle will still remain the same 8"x36"
So each cabinet will require 2 sheets of MDF. If that's the case. It's not a problem.
Old 23rd February 2011, 09:48 PM   #22
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
If you haven't bought the MDF yet, get chipboard, better & cheaper.
We need to know more about the end goals before we can help much,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd February 2011, 09:56 PM   #23
That's it. Other than draw a picture I don't know what would help. What else do you need to know? Maybe your not understanding what I described?
Basically if you could design the ideal T-Line for the speakers described... What shape would you use and why? What volumes and angles etc etc. Thanks I appreciate any help I can get.
Old 23rd February 2011, 10:30 PM   #24
TerryO is offline TerryO  United States
TerryO's Avatar
Your right, I'm not understanding what you're saying. Perhaps you should take some courses in writing. Otherwise, simpleton's like me may not be able to appreciate your genius.
Goodbye...
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 23rd February 2011, 10:41 PM   #25
frugal-phile(tm)
planet10's Avatar
The driver selected has a smallish Vas a high Fs & Qts. TLs for it are gonna look a bit strange... so short that really best as a straight line with no folds.
The Tritrix has a line taper of ~1 to 3 ... here is what Henkjen's SS version of the MJK tables spits out (the specifications are missing a few numbers so i had to estimate them).
Given the spec, these are gonna likely be best put on an OB (with helper woofer), in an IB, or in an aperiodic box.
Also why 2 tweeters? And a generic XO as you have specced is not very useful.
dave
Old 23rd February 2011, 10:46 PM   #26
frugal-phile(tm)
planet10's Avatar
The missing attachment
Old 23rd February 2011, 11:17 PM   #27
dave
OK, what would you recommend? I chose the 2 tweeters to match the four woofers. Because I had to give it a lot EQ. This sounded more balanced. I already built a cabinet with a single tweeter(different one) and this same woofer.
Old 24th February 2011, 07:25 AM   #28
For what reason is the crossover not useful? Please explain.
Old 24th February 2011, 07:31 AM   #29
frugal-phile(tm)
planet10's Avatar
The crossover is hugely critical to get a speaker sounding good. Off the shelf generic crossovers just don't do the job.
dave
Old 24th February 2011, 03:07 PM   #30
Let me guess. Phasing, right. I'm not surprised. I could build one, to correct that.
layered MDF vertical arrayHide this!Advertise here!
Layered plinth for SP-10 jlsem Analogue Source 74 13th April 2009 10:48 PM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Vertical/Horizontal 2 x JXR6 Linear Array as central speaker ? fvaille Full Range 6 11th January 2009 10:20 PM
Layered/laminated plywood dublin78 Multi-Way 31 2nd November 2007 04:57 PM
