First Loud Speaker Box Build Need Help!!!!! - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 19th February 2011, 10:17 AM   #11
Jameslc is offline Jameslc  Australia
The* lol i'm rubbish with english
Old 19th February 2011, 10:28 AM   #12
I will Build them and post a pic when i am done!
Old 19th February 2011, 10:40 AM   #13
picowallspeaker's Avatar
I did suggest that you can even skip the box and leave it...unboxed .
Same thing can be done with a woofer ,given an adequate baffle width to overcome the very first nulls ,that can be outnumbered
by giving massive EQ to the very first octaves ...this implies having drivers with good excursion...and a wide emitting area (most prefer dual 12 or 15" ).
I'm thinking in 'active crossover' mode ,because it is much easier to turn a knob than projecting a passive crossover ...for me . Panomaniac started a thread which I find very instructive :Fast, fun, Inexpensive OB project
Old 19th February 2011, 11:04 AM   #14
I will keep that in mind but wont having an open baffle kill the low freqs and just be all high freq coming out of the woofer ?
Old 19th February 2011, 11:24 AM   #15
each speaker acts as mechanical frequency pass-band
a speaker is a 'constrained spring' ,with the swinging element being the membrane and the attached voice coil ,and has two suspensions .
The mass and material of the membrane dictates some parameters ..which are the mechanical ones ,together with the 'suspension compliance' ,then there are the electrical ones dictated by the magnet force ,the windings of the coil .
So it is impossible for a woofer to reproduce (with same output) the trebles -the cone cannot vibrate at high frequencies because of its mass- same for the tweeters and any dynamic transducer .
I first replied because I feel fraternity to those who start building without thinking too much ...but then there is time for guessing...and correcting...then you realize that the time spent in studying the basics will help you to start with hopefully successful projects .
Old 16th March 2011, 09:22 AM   #16
this is what i have come up with picowallspeaker if your intrested
Iso-Barik 12" woofers ported
6.5'' Midrange ported
1" tweeter
Need a very loud sub box design for wakeboard boat justint Subwoofers 119 17th April 2010 08:59 PM
Using the loud speaker in different way!! anuk07 Multi-Way 1 30th December 2009 06:09 PM
Needed assistance to build speaker box. bentley388 Full Range 4 4th August 2007 03:57 AM
Want knwo how to build hipower amps and loud speakers audiocrazy_pune Solid State 0 25th August 2004 04:31 PM
How Do You Build A 12" Speaker Box jamesrb2004 Subwoofers 3 15th February 2004 07:17 AM
Copyright 1999-2017 diyAudio
