Construction Tips Construction techniques and tips
wanting to build my own low powered amp.
Old 12th February 2011, 06:25 AM   #1
aidynphoenix is offline aidynphoenix  United States
Default wanting to build my own low powered amp.
hello..
i took apart a busted ihome..
there is a little low wattage 2ch audio amp..
does this chip look like a easy canidate for a diy amp?
1-7.5w output
http://www.nxp.com/documents/data_sheet/TFA9842BJ.pdf
i have experience making a headphone amplifier by following the Cmoy pocket amplifer.
can anybody tell without thinking too hard if this will be much harder than building a simple headphone amp from a opamp?
Old 12th February 2011, 06:53 AM   #2
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
why on earth would you use that device?
No harder, but certainly far less satisfying sonically going by the fact sheet...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 12th February 2011, 07:20 AM   #3
well i didnt pick it for quality.. simply wanted to use it because the alternative use is throwing it in the trash...
can you tell me please what on the spec sheet lets you know the sonic potential of the amp?
that way in the future i know which amps are better canidates?
Old 12th February 2011, 02:20 PM   #4
mickeymoose is offline mickeymoose  Canada
The THD value on page 2 and Fig. 6: THD+N
E
Old 12th February 2011, 04:23 PM   #5
thank you!
yea 10% is pretty high i usually see about 00.5THD on alot of things
is there a thread around here that has links to reccomended amplifiers or guides?
thanks guys
Old 13th February 2011, 03:53 AM   #6
go to chip amps forum here. Look at a lm1875 for a real cheap and satisfying first gig. Good luck!
Old 18th February 2011, 02:14 AM   #7
hello again guys.
well im trying to use the audio transistors that i pulled from other things before i threw them away..
this is mostly for learning.
i have two 2SK2645-01MR - N-channel MOS-FET
with the origional heatsinks for them. i dont remember what i pulled these from..
would these be better canidates?
here is the datasheet..
2SK2645-01MR pdf, 2SK2645-01MR description, 2SK2645-01MR datasheets, 2SK2645-01MR view ::: ALLDATASHEET :::
looks like maybe 50w peak?
Old 18th February 2011, 02:47 AM   #8
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Whole different ballgame...
Old 18th February 2011, 04:49 AM   #9
so are those ouf of my league to work with?
wanting to build my own low powered amp.Hide this!Advertise here!
Low Powered Car Amp JustinG Chip Amps 3 1st March 2010 05:13 PM
Booster Amp for low powered SET eeyore Tubes / Valves 23 26th October 2008 12:05 AM
Wanting to build amp systemerror909 Pass Labs 13 2nd July 2008 07:13 AM
Cheap low powered amp AutoAudio Chip Amps 5 16th October 2006 08:21 PM
Newbie, wanting to build Amp PaulHilgeman Solid State 3 8th January 2003 02:24 AM
