Construction Tips Construction techniques and tips
Is it possible to get 15v from 2x15v transformer?
Old 16th January 2011, 02:50 AM   #1
milen007 is offline milen007  Indonesia
Default Is it possible to get 15v from 2x15v transformer?
Hi guys as above
I need 0-15v. However tranformer off the shelf are 15v-ct-15v
Is it possible to get the 15v out while using the full rating?
Can i connect the two 15v and take the 0v from the ct?
Erwin
Old 16th January 2011, 03:22 AM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
Ground the center tap and take 15 V from one of the two ends. Terminate the other end (i.e. cover the end with some heat shrink tubing or some electrical tape). If the secondary is rated for 100 mA you can get 100 mA out of it when wired that way.
Another thing you can do is to use a different rectifier. I assume you'll rectify the output of the transformer with a diode bridge. That will result in about 18~20 V DC. If you instead connect the center tap to ground and connect each end of the secondary to the anode of a diode you get full-wave rectification as well. The cathodes of the diodes go to the reservoir cap. Like this (from Wikipedia):
~Tom
Old 16th January 2011, 04:27 AM   #3
~Tom
thanks tom for the reply.
i need to connected it to the ready made psu board. hence option 2 is not viable.
so option 1 is way to go.. so only taking from one of the tap while leaving the other 15 volt would allow me to get the full rating of the transformer? that is nice to know.
as i was suggested by lokal seller to combine the two 15v taps and take the ground from CT.
just want to confirm
thanks
erwin
Old 17th January 2011, 09:32 AM   #4
No !
connecting the two 15Vac ends is the same as connecting the secondaries out of phase.
That should blow the mains fuse almost instantly.
Use a bulb tester to check your work. Otherwise you may injure yourself or damage your equipment.
The only way to use both 15Vac tappings is the use of the two diode rectifier as in post2. It is only 2diodes. What's difficult about that?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th January 2011, 10:27 AM   #5
pieter t is offline pieter t  Netherlands
Erwin,
Many toroidal power supply transformers are supplied with two separate secondary windings, i.e. 0-15V/0-15V.
When so, there is no single CT, and you could wire the two secondary windings parallel to get the full power of the transformer.
Old 18th January 2011, 03:31 AM   #6
ahh got it.. thanks guys. just talk to the seller again. he said to cut the CT and wire it as a 2x15v. but guess i just order a toroidal with 2x15v
hi andrewT. do you mind show me the link on how to bulb test our work?
Old 18th January 2011, 08:47 AM   #7
insert bulb tester in the search, or dim bulb test, or bulb ballast, google the same
regards Andrew T.
Old 18th January 2011, 10:07 AM   #8
martinbls is offline martinbls  Germany
Hi Erwin,
just to clarify things: Does your transformer has any kind of wireing schematic diagram on it? And if so, does it look like picture 1 or more like picture 2?
Martin
Is it possible to get 15v from 2x15v transformer?Hide this!Advertise here!
Circuit Sanity Check: +15V, -15V, +9V Power Supply miallen Power Supplies 4 18th July 2009 07:18 PM
+/-15V power to a TI PGA2310. 15V regulators sufficient or do I need adjustable?? nick_g_evans Parts 2 16th July 2008 11:50 AM
DC/DC 12V-15V inducterless Transformer Circuit needed Tempest_au Power Supplies 6 22nd May 2007 12:37 PM
WTB: small toroid 2x15V 50VA AR2 Swap Meet 0 3rd December 2006 03:17 PM
FS: 2x15V / 50VA transformers Bakmeel Swap Meet 0 15th July 2004 07:13 PM
Copyright ©1999-2017 diyAudio
