Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 9th January 2011, 07:44 AM   #1
Default Wiring SPST Switch with Neon Lamp
Hi gang,
I' ve got a lighted SPST switch I'm going to use on a microphone preamp I'm building. The switch has a built-in neon lamp. I'm confused because there's 3 terminals coming out the bottom of the switch. When I connect a DMM to terminals 1-2, I get continuity when the switch is on. Across terminals 1-3, or 2-3, there is no change when I flip the switch to either position.
I am attaching the datasheet for the switch. This will be the switch that energizes the power torroid, so it will be connected directly to mains. I don't want to make a stupid mistake.
Can anyone advise how to wire this correctly? I am attaching both the datasheet for the switch, as well as a crude layout/wiring diagram of the power supply. The "front panel switch" at the bottom of the diagram is the neon lighted switch in question.
Thank-you,
Mike
Crude Wiring:
Switch datasheet:
Power Switch CR_Series.pdf
Old 9th January 2011, 08:05 AM   #2
After more research, I ran across a post on another forum that suggested something like this. I did not indicate the neon lamp between terminals 2-3, but they are indicated on the datasheet. What do you think?
Thanks,
Mike
Old 9th January 2011, 04:11 PM   #3
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
Only one switch has the neon in the PDF the CRE22F2BBRLE
this is wired 1 to Live, 2 to torroid 3 to neutral, so the light comes on when the power is switched on, if you swap 1 and 2 the neon will stay on all the time...
your wiring is correct, don't forget to sleeve the contacts for safety
Old 9th January 2011, 06:31 PM   #4
Excellent; thank-you!!!
Would you see a problem using .25" crimp connectors with insulation on them, or is using crimp contacts a bad idea?
Thank-you again!
Old 9th January 2011, 07:25 PM   #5
Spiny's Avatar
I use 1/4" insulated crimps where the switch has them reliable and safe when the top is off the equipment.
Old 9th January 2011, 08:28 PM   #6
Lol you're funny!
Thank-you!
Elevam's oversized Neon Lamp for Micro Seiki 5 - where to order tiefbassuebertr Analogue Source 10 5th June 2012 02:23 PM
Looking for small SPST SMD "switch" (cmos?) luvdunhill Parts 5 22nd March 2010 08:11 PM
Quad SPST Analog Switch RCruz Solid State 7 25th November 2008 12:07 PM
USA source for rotary spst switch? riotubes Parts 11 22nd October 2006 02:52 AM
Where can I get a neon lamp for Garrard 401? honinbou Analogue Source 12 10th March 2006 06:56 PM
Copyright ©1999-2013 diyAudio
