Construction Tips Construction techniques and tips
Removing solder from PCB eyelets
Old 4th January 2011, 02:36 PM   #1
john dozier is offline john dozier  United States
john dozier's Avatar
Default Removing solder from PCB eyelets
Iam relacing some caps on a DAC pcb. Removing the old caps is going well, but there is solder remaining in the eyelets. Wicking does not help. They are too small for toothpicks. What a PITA! Any suggestions would be appreciated. Thanks
Old 4th January 2011, 02:44 PM   #2
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Try a Desoldering Vacuum Bulb.
Radio Shack #64-2086 or #64-2060
Kevin
Old 4th January 2011, 02:56 PM   #3
Andy5112405 is offline Andy5112405  United Kingdom
Banned
Rather than risking damaging the board just heat up the pads when you insert the new components.
Old 4th January 2011, 03:26 PM   #4
macboy is offline macboy  Canada
I sometimes remove as much as I can using a pump and/or wick, then carefully drill out the last little bit using a drill that is just slightly smaller than the hole. I have a set of numbered drill bits (#61 - #80) and I use an X-acto knife handle as a chuck to manually drill out the solder. The solder is so much softer than the copper that it can be removed without damaging the plated hole.
Old 4th January 2011, 03:30 PM   #5
DualTriode is offline DualTriode  United States
Hello,
Try this it has worked for me.
Before you remove the existing part use wick and your iron to remove as much of the original solder as possible. If you have any luck many of the eyelets will remain open when you remove the part. Strip a piece of stranded wire, twist it snug between your fingers, tin the very end with your iron then snip off the end on a diagonal to make it sharp. Apply some heat to the closed eyelet and insert the wire where you were thinking of using the toothpick. The wire will act as a long skinny piece of wick.
Done!
Old 4th January 2011, 03:38 PM   #6
Andrew Eckhardt is offline Andrew Eckhardt  United States
Heat it up. Blow through it. If that doesn't work, heat it up and rap it on the bench at an angle that will force the molten solder through and out the eyelet.
It's messy, but it works.
Old 4th January 2011, 03:42 PM   #7
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Seconded.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 4th January 2011, 06:03 PM   #8
ArtG is offline ArtG  United States
Thirdid!
I do this all the time. Be aware, however, that molten solder will fly around, and sometimes end up in places you don't want it, like on your hand. Just be careful.
Old 4th January 2011, 06:27 PM   #9
tomchr is offline tomchr  Canada
tomchr's Avatar
This is the best solder sucker I've ever used. On stubborn holes, I will re-tin the hole and suck out the new solder. That usually works. A little flux might help too.
~Tom
Old 4th January 2011, 06:44 PM   #10
Thanks for the tips. I ordered a desoldering iron and bulb from parts express. Had excellent review and $30 delivered. I will let you know how it works. Thanks again. Btw tomchr, there was no link inyour reply. I would like to know what sucker you are using.
Removing solder from PCB eyeletsHide this!Advertise here!
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 03:13 PM
small help with Marantz 6000 mod (removing PCB) sanjeev Digital Source 0 6th June 2009 02:02 AM
Removing Solder Pins from Heatsinks luvdunhill Parts 8 7th April 2008 01:12 AM
Need PCB solder side pictures of x7esd and 557esd beauty_divine Digital Source 0 20th October 2006 06:58 AM
Strengthening PCB tracks with solder? Cradle22 Solid State 11 14th March 2003 06:33 PM
