Construction Tips Construction techniques and tips
Removing solder from PCB eyelets
Old 4th January 2011, 07:47 PM   #11
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Removing solder from PCB eyelets Send a message via Yahoo to vdi_nenna
I use the Radio Shack solder sucker, like the digi-key item tomchr provided. It's this blue pen like device with a plunger, but I heard that this creates static electricity, so use caution.
Regarding the solder wick, maybe you need a higher powered or adjustable iron?
Just a thought.
I build, therefore I am.
Old 4th January 2011, 07:51 PM   #12
auplater is offline auplater  United States
auplater's Avatar
30% v/v of 69% (commercial grade) Nitric acid
15% v/v of 45% Ferric Nitrate soln.
0.7% v/v of 37% Hydrochloric acid
should take maybe 5 minutes or so to strip the solder (depending on thickness)
If you don't know how to follow the mixture above, don't mess with it... you'll hurt yourself
This is how solder masks are stripped commercially
John L
"I've forgotten more than I care to remember" The Last Conspirators
Old 4th January 2011, 09:20 PM   #13
john dozier is offline john dozier  United States
john dozier's Avatar
I am a EE not a ChemE. I think I will pass. Also I would be concerned on the acids effect on the eyelets themselves. Thanks for the alternative though!
Old 4th January 2011, 10:46 PM   #14
auplater's Avatar
Default OK
best not to quit your day job, then...
This mix is designed specifically not to affect the eyelets, when used correctly. It also noticeably improves the intertrace resistance over stock methods.
I'd be a bit concerned about all the solder sucking/heating/manipulations affecting the eyelets as well... re-work danage is real and significant... easy to cause microfractures in the traces, through holes, and/or substrate at minimally controlled elevated temperatures... that's why room temp wet processes were developed industrially..
Cheers...
John L.
Old 4th January 2011, 10:56 PM   #15
tomchr is offline tomchr  Canada
tomchr's Avatar
Btw tomchr, there was no link inyour reply. I would like to know what sucker you are using.
The word "This" in my reply is a link. Here's the site it links to:
Digi-Key - K414-ND (Manufacturer - DP-200)
~Tom
Old 4th January 2011, 11:17 PM   #16
Thanks for the link. I will order one tonight. You can never have too many desoldering tools. When I took a break to go back for my doctorate, I was heavily involved in equipment modification. After returning to the workforce, I had no time for it. Thus I am starting over in this field and find that methods of construction have changed and I am playing catchup. I am now semi retired and have time to once again"fiddle about" Thanks for all the help
Old 5th January 2011, 12:40 AM   #17
DualTriode is offline DualTriode  United States
John L
Hello,
I am able and willing. Please tell us the rest of the story.
I can imagine pickling the entire PCB. I am having difficulty picturing using your pickle juice on a limited area of a populated board inside my new OPPO BDP-93 without splashing everything everywhere.
Be careful not to get smoke in your eyes.
DT
All just for fun!
Old 5th January 2011, 05:10 AM   #18
qusp is offline qusp  Australia
qusp's Avatar
decent braid twisted to a point plus flux and a hot iron usually works for me, for more stubborn ones I also use the whacking method above
Old 5th January 2011, 05:51 AM   #19
Aucosticraft is offline Aucosticraft  India
Iam relacing some caps on a DAC pcb. Removing the old caps is going well, but there is solder remaining in the eyelets. Wicking does not help. They are too small for toothpicks. What a PITA! Any suggestions would be appreciated. Thanks
Simple method I had be using for years as a hobbyist, I heat the solder to melt. Then blow heavily into eyelet to clear. this method is ok if you wish to replace few components at home. I don't prefer to use pump because they could rip track or pad when gets heated.
There is always a first time....
Old 5th January 2011, 06:45 AM   #20
stratus46 is offline stratus46  United States
Originally Posted by macboy View Post
I sometimes remove as much as I can using a pump and/or wick, then carefully drill out the last little bit using a drill that is just slightly smaller than the hole. I have a set of numbered drill bits (#61 - #80) and I use an X-acto knife handle as a chuck to manually drill out the solder. The solder is so much softer than the copper that it can be removed without damaging the plated hole.
ABSOLUTELY stay away from drills on PCBs. Get a decent soldering tool and you won't need to play with drills, toothpicks and chemicals. A Metcal STTC-126 soldering tip will allow you to clean out nearly any PCB hole you're likely to run across. I have had a few problems with some XFX nVidia graphics cards as they chose not to use thermal reliefs so you're de-soldering a heatsink. It just takes a little more time to get it heated up. For nearly everything else I have no problems using the Metcal iron and a solder sucker, sometimes doing a 'clean up' using Solder Wick and not that terrible Easy Braid.
G
Removing solder from PCB eyeletsHide this!Advertise here!
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 04:13 PM
small help with Marantz 6000 mod (removing PCB) sanjeev Digital Source 0 6th June 2009 03:02 AM
Removing Solder Pins from Heatsinks luvdunhill Parts 8 7th April 2008 02:12 AM
Need PCB solder side pictures of x7esd and 557esd beauty_divine Digital Source 0 20th October 2006 07:58 AM
Strengthening PCB tracks with solder? Cradle22 Solid State 11 14th March 2003 07:33 PM
