PCB drilling with a dremel - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 4th January 2011, 01:16 AM   #21
Krisfr is offline Krisfr  United States
Krisfr's Avatar
What is the BEST solution as in liquid (suspension), to tin the board to prevent corrosion?
Never give a Systems Analyst a screwdriver or hammer
Old 4th January 2011, 11:37 AM   #22
liquias is offline liquias  Israel
I second this question. I too would like to know ...
I have heard of a material called Liquid Tin by MG chemical, but it is not available to Israel, so I never used it. I currently do not tin plate my boards, but I laminate them using sprayed laquer.
Old 4th January 2011, 02:56 PM   #23
theAnonymous1's Avatar
I used to use "Tinnit" tin plating chemicals that can be purchased from Parts-Express......
Tinnit Tin Plate | Parts-Express.com
It works OK, but smells horrible (like hair perm).
Lately I have been making my own silver plating powder out of silver nitrate, salt, and cream of tartar. Silver nitrate makes one heck of a mess though; getting it on your skin leaves nasty dark stains that can stay there for weeks. If I didn't already have a bunch of silver nitrate I would probably buy some Cool-Amp powder....
http://www.cool-amp.com/cool_amp.html
Old 5th January 2011, 03:26 AM   #24
MJL21193's Avatar
Originally Posted by Krisfr View Post
Less than 10 bucks on SALE Total
A word about drill bits: they aren't created equal. There are some really terrible ones out there that are too soft to be called HSS. Usually, these are the cheap ones.
Old 5th January 2011, 03:54 AM   #25
qusp is offline qusp  Australia
qusp's Avatar
I have the dremel drill press attachment, which is kinda useful, but not very rigid or accurate, do you guys have any solutions? I mainly use the extension attachment pictured earlier, but wonder if its worth pursuing the dremel for drill press duties, or whether I would just be better off getting a drillpress
Old 5th January 2011, 04:01 AM   #26
I have the Sears version of the Dremel drill press. I don't know how much of a difference there is to the Dremel version (maybe just the name on the sticker). It did take a little bit of gentle modding to get the bits to be perpendicular enough to not break.
A regular drill press doesn't spin fast enough for carbide bits, so you would have to use HSS. My regular drill press also has a bit of "wobble" in the chuck that makes it impossible to use with any really small bits without either breaking them or creating an irregular hole.
Old 5th January 2011, 10:52 AM   #27
jackinnj's Avatar
I only use the carbide bits in the Grizzly mini-mill. It is sometimes bit inconvenient to use the mill, however, since it takes a bit of time to rig the pcb to the base.
For anyone interested, there's a belt-drive adapter for the Grizzly Mini-Mill from Little Machine Shop which reduces the vibration quite a bit.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 5th January 2011, 11:55 AM   #28
stoN_Cold's Avatar
Carbide bits, the best solution, but request high speed!
Click the image to open in full size. Click the image to open in full size.
No handheld, only stand.
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
This stand is real DIY .
Regards zeoN_Rider
Old 5th January 2011, 03:57 PM   #29
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
my 12V drill also has a little wobble in the chuck depending on how you tighten it. I made a constant speed control (increases voltage depending on motor current when the motor is loaded to maintain speed with increased torque. touchy feedback adjustment though, but once set, works wonderfully)
I tighten chuck then adjust speed for the least vibration on drill bit. never broke a carbide bit since then, used down to 0.6mm bits successfully.
Old 5th January 2011, 04:13 PM   #30
Just did a series of six 0.25MM holes with my dremel press before the bit snapped. I have no use for a hole that small though. I think the only reason it snapped was because the bit needs to be 100% perpendicular to the board (which it isn't); the dremel press just wasn't built with that kind of precision in mind.
PCB drilling alternatives nemestra Parts 11 11th April 2008 12:29 AM
Drilling a PCB KP11520 Everything Else 34 12th September 2007 01:28 AM
Jobmate Dremel - For Canadians EdT Everything Else 0 22nd February 2007 07:00 PM
Tools? Dremel or Rotozip? Pyro Equipment & Tools 7 16th March 2002 04:43 PM
Copyright 1999-2017 diyAudio
