Construction Tips Construction techniques and tips
Soldering iron tip problem, help!
Old 31st December 2010, 07:17 PM   #1
audio_tony is offline audio_tony  United Kingdom
Send a message via MSN to audio_tony
Default Soldering iron tip problem, help!
Firstly, a bit of background.
I have worked (both professionally and as a hobbyist) with electronics for 30 years or so.
I'm having a problem with what I think is lead free solder, and tinning of the bit.
My temperature controlled iron is set to between 240 and 270 deg C.
But I cannot get the tip to 'tin' properly - no matter what I try.
I did have some mild success tinning it with some 'Resin Core Solder Wire' that I purchased some years back. I don't have any chemical info on this solder - all it says on the reel is "with resin flux core".
The solder I'm currently using is made by 'Shenmao' and is a 'lead free' solder composed of 99.3% 'Sn' and 0.7% 'Cu'.
I have tried an alternate solder but this has the same chemical composition.
I have attached a picture of the bit I'm currently using (large because I'm working on a PSU for my amp!).
I would be truly grateful if anybody has any suggestions!
Old 31st December 2010, 07:33 PM   #2
firechief is offline firechief  United States
firechief's Avatar
Is there a reason you need that particular solder? Try as a test, going to the local suplier and pick up some clasic 50/50 tin lead stuff and just see if it helps. Its one or the other, temp, or solder composition.
What changed? What is different from the good results that you are used to?
Old 31st December 2010, 07:37 PM   #3
tomchr is online now tomchr  Canada
tomchr's Avatar
It looks like the tip is really dry (as in no solder on it). I would try some tip tinner. If that doesn't work, "paint" the tip with flux using a flux pen or liquid flux. Do this when the tip is cold. Then turn the iron on and hold a piece of solder to it as it warms up. If that doesn't do the trick, I'm afraid the tip is dead.
~Tom
Old 31st December 2010, 07:39 PM   #4
The only things that have changed most recently are the tips.
Tinning the bit has always been problematic though, and I've often had to resort to a bit of gentle treatment with sandpaper.
The tips always seem to go gray / black.
I don't leave the iron on for prolonged periods so it's not that.
I have a moist sponge and keep the tip (once successfully tinned!) as clean as possible whilst working.
One thing I did wonder about, is that I have been working on a lot of older kit, probably assembled with the older lead solder. I did wonder if mixing the types is causing some kind of contamination?
Old 31st December 2010, 07:43 PM   #5
firechief's Avatar
Yea - sounds like you are doing everything right- Just because the readout on the iron says 270 degrees it might be that it is not heating enough. Does it sizzle when you touch the hot sponge? Would be nice to have a way to measure the temp of the tip. hmmmmmm
Old 31st December 2010, 07:48 PM   #6
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Your temperature is too low, set it to 270.
The solder you have purchased is unsuitable for electronics work, it appears to be silver solder for jewellery work and probably does not contain flux.
Purchase some electronics solder, Maplin sell lead free if you are stuck, but I use leaded solder.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 31st December 2010, 07:55 PM   #7
This was purchased from Maplin!
Here is a link to the very product!
If the link doesn't work, search for code N31AR
Interesting to note in the Q&A that it appears to be suitable for electronics?
Old 31st December 2010, 07:56 PM   #8
firechief's Avatar
So - the solder "99.3% 'Sn' and 0.7% 'Cu" would need to be used with a torch, is that correct?
Old 31st December 2010, 08:03 PM   #9
I found a datasheet for this solder.
Hopefully it should be attached!
Old 31st December 2010, 08:16 PM   #10
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
Having the iron too hot shortens the life of the tip.
I have had problems in the past with tips and it was iron was too hot or the iron was left on for prolonged periods while not being used, both shorten tip life.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Soldering iron tip problem, help!Hide this!Advertise here!
How does OKi MFR soldering station set tip temperature? speakerguy79 Parts 0 25th March 2008 08:02 PM
Weller soldering iron problem rtarbell Parts 2 23rd June 2007 04:48 AM
Correct Size Soldering tip for RCA plug billiam Analogue Source 3 11th March 2005 06:16 PM
Craftsman soldering iron tip thread size? Darren Nemeth Parts 0 10th February 2005 06:50 AM
