| Construction Tips Construction techniques and tips |
#11 |
Hello
These paper use to be the best! Now available only in 100 sheets .I used up one 30 and one 100 sheets. After I went to Kinko's I used their paper but right now they change the quality of the paper to. Both side glossy. Usually to me that does not work. Be careful these Staples paper have to be glossy! The blue cover has plastic on the paper , right away stick on my iron ![]() I hope I could help. Try that method I advised to you , even the plastic transfer foil work to in that way. Paper is better because you can socked done and it comes out better. BTW the number of the 30 sheets 471861, the 100 sheets end with 65 but that was not so good than the first one , but still works well. I didn't tried the new paper yet! Greetings. Last edited by gaborbela; 31st December 2010 at 09:49 PM. |
#12 | |
Amazon.com: HP Color Laser Presentation Paper, glossy: Office Products HP Color Laser Presentation Paper, 8 1/2" x 11", 34 lb. | Staples® HP Color Laser Presentation Paper Glossy 8 12 x 11 34 Lb Pack Of 300 Sheets by Office Depot HP Color Laserjet Glossy Presentation Paper - 97 Brightness/32 lb. - 8 1/2" x 11"; 300 Sheets - Sam's Club
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#13 |
That's the stuff I threw in the garbage. It wasn't bad, but it doesn't release from the PCB very well. The HP presentation paper literally justs falls off when soaked.
#14 |
Hello
That paper works just takes time to sock the paper and you have to rub with your finger! Use 45-50C degree water. Is good to know there are better papers out there.. Greeting |
#15 | |
Hi Gaborbela,
Yes, I used 130 of those older sheets. They are NOT the same now. That was my point. Quote:
![]() I'll have a look on Sunday. HP's website is not showing it either. I didn't want to have to order from the States unless I have to. |
#16 |
Hello MJL21193
Good to know because I just need paper to.. Thank to letting us know! The HP paper is thick photo paper or thin normal paper just glossy?? gabor |
#17 |
There are HP papers on ebay it would be great if someone could post a picture from the good paper.
Many of them use plastic coating those are not good also! Thanks Greetings |
#18 |
It's thin like magazine pages (the thicker variety though).
Here is the first Canadian source I could find..... Office Supplies: Office Products and Office Furniture: Office Depot
#19 |
No dice:
1116.PNG I wonder is the HP matte finish usable? I tried some matte Epsom I have and it wasn't great but it did transfer. EDIT: scratch that, the matte isn't in stock either. Last edited by MJL21193; 31st December 2010 at 10:41 PM. |
#20 |
Here, I found a scrap piece of the old Staples paper and took a pic of it next to the presentation paper. The photo paper is on the left.....
| WHICH Laminator for Toner Transfer? | RaymondW | Equipment & Tools | 35 | 28th April 2012 03:31 PM |
| Toner transfer problems | john blackburn | Construction Tips | 11 | 11th December 2010 08:54 AM |
| I tried toner transfer today... | gmikol | Parts | 11 | 13th December 2006 06:00 AM |
| Laminator for PCB Toner Transfer? | dfdye | Parts | 16 | 29th May 2006 02:52 PM |
| Toner transfer with a twist -- anyone tried this? | rif | Everything Else | 17 | 7th September 2005 12:10 AM |
