Toner Transfer Paper Problems - Page 10 - diyAudio
Go Back   Home > Forums > Design & Build > Construction Tips
Construction Tips Construction techniques and tips
Old 26th January 2011, 02:58 PM   #91
who supplies the toner?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th January 2011, 03:37 AM   #92
MJL21193's Avatar
Originally Posted by theAnonymous1 View Post
Sorry to hear the laminator didn't work out.
EDIT: Just out of curiosity, what is the power consumption of the Staples laminator? The H212 is 480W.
Not a big deal. I make an average of a board every 2 - 3 days when I'm 'into' this (which I am now) and, like I said above, it isn't much of a hardship to use the iron.
I didn't notice how many watts the unit was and I returned it the same day. The web site doesn't list the specs either, as far as I can see.
I first let it heat up until the 'ready' light went on, then I left it for about 10 minutes more to see if it made a difference.
Old 27th January 2011, 03:40 AM   #93
MJL21193's Avatar
For my printer? HP printer, HP toner.
I think I need a new one soon - seems that maybe the fuser is starting to crap out and that printer has seen a LOT of action.
Old 27th January 2011, 03:50 AM   #94
ostripper's Avatar
All those boards are hard on the toner .. aye !! $70 a pop I am running out as well. My plan is to buy a refill (not HP original ) for 20$ and just use the new $70 genuine for PCB's. I might even try to refill my existing one myself (messy).
If you get a new printer , use the old one as a DIY PCB laminator. I read that the old laser printer fuser will run independant of the printer mounted on a board running on just standard AC. PS , the OEM laminators are junk , I trashed one with just 2 PCB's.
I did get the laminator to work by increasing it's temp to from 160 to 180C(HP toner melting point). This caused the plastic bearings to deform , which really ticked me off. I looked at my HP printer , it has metal bearings and a spring loaded fuser tension adjust ... would make the perfect laminator since it is set for the HP toner natively and could self adjust to various PCB widths.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 27th January 2011, 04:10 AM   #95
MJL21193's Avatar
When I get a new printer, I will look my old one over to see if it is possible to modify it to direct print to the board surface. Maybe a project worth trying, I think.
According to the manual, the printer consumes 380 watts when printing. I'm not sure if that is hotter than the Staples laminator I 'borrowed'.
I read somewhere about doing the transfer in an oven. Sandwich the board and paper between two pieces of thick glass (I think I'd use steel) and squeeze it together with a couple of spring clamps. Heat the oven to 400* and let bake for 20 minutes.
Old 9th December 2011, 01:15 AM   #96
I tried the Staples brand laminator ($100) without success. It simply doesn't get hot enough. I ran the board through 4 times and it still hadn't started to stick.
I think I'll stay with the clothes iron. It really isn't much of a hardship and certainly isn't the most unpleasant aspect of the process - cleaning the board is MUCH worse.
I have a $30 generic laminator from Walmart. It works good with my Samsung printer and magazine paper. I have the original Staples paper, but it doesn't work well with my printer. Your HP results look impressive. I will give them a try.
Old 9th December 2011, 02:34 AM   #97
PB2 is offline PB2  United States
PB2's Avatar
What model is that laminator?
Old 14th December 2011, 03:22 AM   #98
WMC850HC
It's a generic printer. On mine, the shell was slightly warped, so I need to remove the screws on the back to so that the PCBs can slide through without binding.
Old 15th December 2011, 11:26 PM   #99
Here's a section of a double sided board I just made. The traces are 15 mil wide. I could easily have used 8. The via pads are 50mil dia. I used a Club Toyata magazine page for the toner transfer. The board was etched with copper chloride, which never needs to be disposed of.
The printer cost $40. The laminator was $30. They already paid for themselves after 2 boards.
Old 8th February 2012, 01:26 AM   #100
roline is offline roline  United States
roline's Avatar
I've been using HP LASER PRESENTATION PAPER, Q2546A with good success. By using max ground plane, there is minimum etch area so it lasts longer. I always tin plate to protect the copper.
SO many tubes, SO little time!!!
WHICH Laminator for Toner Transfer? RaymondW Equipment & Tools 46 22nd February 2017 02:56 PM
Toner transfer problems john blackburn Construction Tips 11 11th December 2010 08:54 AM
I tried toner transfer today... gmikol Parts 11 13th December 2006 06:00 AM
Laminator for PCB Toner Transfer? dfdye Parts 16 29th May 2006 02:52 PM
Toner transfer with a twist -- anyone tried this? rif Everything Else 17 7th September 2005 12:10 AM
Copyright 1999-2017 diyAudio
