Construction Tips Construction techniques and tips
To etch or not to etch-that is the question?
Old 18th September 2010, 08:05 AM   #1
jrgoswick is offline jrgoswick  United States
Default To etch or not to etch-that is the question?
My first DIY is fast approaching. I would like a little input from the community about a MAJOR issue I'm confronted with. Should I etch boards for this? Should I bread board it, and go point to point? Should I wire wrap it?
1)-Etching- While I can do this, is the time worth the investment? It's been YEARS since I've etched anything(about 10 years, college was a long time ago). Will it sound better than a non etched amplifier? Any thoughts.
2)-Bread board and point to point-This I can ALSO do. While this may be the easiest to do, are there any major drawbacks to it? Will sound quality suffer from this method versus an etched board?
3)-Wire wrap-Again, I can do this, but it's a MAJOR pain in the rump(and I don't have the tools for it).
Any thoughts, inputs, suggestions welcome/needed. Should also mention a bit about this thing. Rails are about 70v+-, it's a BJT amp, not a FET. AND, for the most part, each channel is commercially available in a stereo amplifier. Each amp has a pair of devices per rail per channel. I'm planning on using BOTH set of devices paralleled per channel(total of 4 pairs per channel) for a higher operating current. It's a totally discrete amplifier, with a VERY straight forward A/B topology. I don't actually plan to double the rated power(150WPC) of this amp, MAYBE(and this is pushing it) 225 to 250 WPC, with a low THD(.09 or lower). It will be driving a pair of Monitor 12B Polk's that have had the treatment(upgraded XO's, tweets, ect.....).
Old 18th September 2010, 09:47 AM   #2
read Gootee
Printing Circuits
regards Andrew T.
Old 18th September 2010, 12:27 PM   #3
jcx is offline jcx  United States
Default do you want to be a etching hobbyist or build amps?
for through hole discrete components perfboard or clearance hole gnd plane with point-to-point can be electrically better than single layer pcb - you should look closely at a number of such builds to see the possibilities
add a little work with Kapton and copper tape, xacto knife to peel up gnd plane in some areas and you can even compete with 4-layer layout quality
if you were going for more than 2 channels I would get 2 layer, plated through hole pcb made from one of the many cheap pcb houses
I think the mess, chemical disposal issues and time involved to get poor quality homebrew pcb isn't competitive with today's pro prices
Old 18th September 2010, 01:17 PM   #4
Anchan is offline Anchan  United States
I agree with jcx. I think you'd be a bit crazy to do the whole homebrew etching process. I use this place:
ExpressPCB
Free software, and 3 boards for $50.
There are a few others including PCBexpress which has slightly fancier software. If you do a search you'll find others. The boards are delivered in just a few days after you push send from your computer! No mess and and high quality.
If your circuit is simple enough, just buy some perf and solder point to point.
Wiring wrapping can be fine, but not for anything high voltage or high current like amps.
Old 18th September 2010, 02:21 PM   #5
Krisfr is offline Krisfr  United States
Krisfr's Avatar
The 51 dollar price is only for a very small board. What would the typical size (and price) be for a medium size (wattage) amplifier?
Old 18th September 2010, 02:30 PM   #6
wakibaki is offline wakibaki  United Kingdom
Banned
If you like your results quick, there's nothing to beat making the boards yourself. Etch or isolation rout, I've used both. The problem with etching, you have to drill manually. The problem with routing, sometimes the isolation fails. The problem with either, no plated-through holes, so all your connecting tracks have to be on the side opposite the component, and you have to create vias by hand.
It's incorrect to suggest that a homemade PCB will be poor quality.
PCB has a big advantage over wire wrap and perfboard. If your schematic is right and you stuff the board right the connections will be right i.e. it will work.
Perfboard is hygroscopic and is only really any good for short-lived prototypes and low frequencies. Plus you have to think while you're constructing on it. I'd rather make a PCB even for something simple, and because it's easy, I do.
You will be more productive and more creative if you do not depend on a PCB manufacturer and postal turnaround. It's like the difference between old-time film photography and digital. The quicker and easier you get the feedback, the more you do and the more you learn. It's easier to commit to making a board yourself than it is to commit to spending $50, and you still have the option to do that once you've proved the design.
w
Old 18th September 2010, 02:33 PM   #7
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 To etch or not to etch-that is the question?
I think it is a matter of taste. Or you etch your own boards (like I do!), or order from those express services. Doing this at home is much cheaper, but takes time, and you MUST love that! For me, drilling is the toughest part of the whole process. Although I use a manual punching tool, larger holes ask for appropriate drill.
Max.
Max.
Old 18th September 2010, 02:35 PM   #8
Krisfr's Avatar
Originally Posted by AndrewT View Post
read Gootee
Printing Circuits
The "Staples" brand paper that the article mentions does not seem to be available. Does anyone have a thought as to a viable substitute?
Old 18th September 2010, 04:25 PM   #9
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Forget about glossy photo paper. I've used many different kinds, even the staples stuff, and it's a pain to remove all the paper from the PCB once it's transfered.
I've switched to "Glossy Presentation Paper" and will never go back to photo paper. The stuff I bought was HP brand (Q2546A).
You can see my results with it here.....
http://www.diyaudio.com/forums/equip...ml#post2150475
Old 18th September 2010, 04:41 PM   #10
indianajo is offline indianajo  United States
indianajo's Avatar
[QUOTE=jrgoswick;2306935]
Forget wirewrap. It works fine for 3V logic signal swings, with gold pins, but my H182 organ has some on the preamp, and even with 40 mv Hammond signals, some of the pins had to be soldered by dealer service. Music goes too soft and low voltage for wirewrap. There should be tons of wirewrap surplus on the market now, but I think it all went immediately to the gold recycler. I used to do it professionally, liked doing it, but logic only.
I don't know the world, but newark is charging about $20 for perfboard drilled, and triodeelectronics is charging $10 for a turret board with about 40 turrets. The turrets are so far apart, it is more suitable for tube circuits, not for signal transistors. I've got 6 transistors and about 20 other things crammed on a 1.5"x2.5" board that fits in my ST120 amp where the new smaller bypass caps left a little room. At my income level I found some surplus HV circuit breaker boards at a sale of stamping presses. Have been stripping the big brass screws and drilling them myself, at 4 pockets full of boards for $1. I realize now, if I didn't luck into that, I could buy lexan sheet at the lumber supply and cut it with my sabre saw and drill. Neither is hydroscopic. Much cheaper than pro perfboard, and I haven't broken a #33 drill yet. (I sharpen them myself with a 7" grinder). Some teflon or kynar wire to resist inadvertant burns, I've done a couple of projects. Fatter wire for power circuits, I've been salvaging from dead PC power supplies. Triodeelectronics has some fabric 22 solid wire in 10 colors, resists burns better than pvc and he sells a twist of each color for $2. I'm making standoffs to hold the board off the chassis or heat sink by cutting up 1/4 nylon air tubing and using #6 screws and nuts. Been salvaging heat sinks from dead factory VFDrives.
My computer is too weird to run windows compatible layout software. Anybody got any linix compatable routing software,pipe up. I would think about it if I want to sell something.
Been looking at little microamp pcb's from tonepad for little 1 dual op amp circuits. Not everything can be done with TO92's. Those little dip pins are awfully close together for soldering, and easy to overheat. These would be installed on a bigger perfboard for the rest of the circuit.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
To etch or not to etch-that is the question?Hide this!Advertise here!
What does industry etch with richie00boy Everything Else 12 3rd September 2007 06:07 PM
Etch Resist Stripping richie00boy Parts 13 29th August 2005 08:05 PM
PCB Etch Probs richie00boy Parts 18 21st July 2004 02:18 PM
Copyright ©1999-2017 diyAudio
