Construction Tips Construction techniques and tips
Can i connect a cap with wires?
Old 14th August 2010, 09:29 PM   #1
rg12 is offline rg12
Default Can i connect a cap with wires?
I have two 10,000uf caps that have 5 legs and really long distance
between the two legs that are actually connected (25mm).
I was wondering if it's acceptable to solder to wires for the + and - to
the pcb and solder the other side to the + and - of the cap.
Another thing i wanted to know, is if it's ok to place the caps upside down.
Roi.
Old 15th August 2010, 12:15 PM   #2
glennb is offline glennb  Australia
Sure, it will lower the ESR very slightly. Just don't connect connect + to - !!!
Yes, elec caps can be run at any angle, no sweat.
Glenn.
Old 15th August 2010, 12:19 PM   #3
Thanks buddy!
Can i connect a cap with wires?Hide this!Advertise here!
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 03:05 AM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 07:47 PM
Low-ESR cap -vs- Normal cap with sunbberized. nina Chip Amps 11 11th September 2005 08:20 PM
Can a X2 cap be used in place of a snubber cap? w00t Parts 6 26th February 2004 03:50 PM
.22uf cap in place of .25uf coupling cap, OK? bbaker6212 Tubes / Valves 5 15th July 2002 10:08 PM
